Need some help with relocated battery wiring
Old Dec 21, 2006 | 11:29 PM
gracer7-rx7's Avatar
needs more track time
Unhappy Need some help with relocated battery wiring
I relocated the battery to the passenger side bin and then ran the 2 gauge wiring directly to the starter. I did this so that I could have a shorter, more direct wiring path. It seems a few people have done this also but for some reason its not working for me.
I'm using a 150AMP Stinger circuit breaker like in Moconnor's thread about 18" of wiring from the battery. It is grounded to the B pillar where there is a factory ground There are no kinks or exposed wiring.
When I try and connect the terminals to the battery, it starts sparking like crazy. Doesn't matter which terminal I connect first. As soon as I connect the 2nd terminal, I get crazy sparks.
Circuit breaker hasn't blown.
Can anyone shed some light on what might be wrong? Much thanks.
Old Dec 21, 2006 | 11:47 PM
compuskills's Avatar
Maybe you need to work on your grounds to the motor.
Old Dec 22, 2006 | 12:00 AM
moconnor's Avatar
Did you attach the cable to the correct terminal on the starter solenoid?
Old Dec 22, 2006 | 12:38 AM
I thought I did. Here is a pic with the attachment to the starter.
Worked fine when I had run the power all the way to the stock location. Not working when run to the starter like it is in the pic.
Thanks for the input.
Attached Thumbnails Need some help with relocated battery wiring-cimg0036.jpg
Old Dec 22, 2006 | 12:43 AM
More pics
Attached Thumbnails Need some help with relocated battery wiring-cimg0048.jpg
Old Dec 22, 2006 | 12:53 AM
****. Now that I look at the pic of the starter in large format, I see that I think I might have connected to the wrong point on the starter.
There was such little room to maneuver under the car that I hadn't noticed the covered terminal until I looked at the pic.
Oops...
Old Dec 22, 2006 | 01:03 AM
moconnor's Avatar
Yup - current is going directly to the starter rather than being switched through the solenoid.
Old Dec 22, 2006 | 10:09 AM
badddrx7's Avatar
All Spooled Up
^ - like he said. Your car was tryint to start when you attached your cables. Take your time and hook everything up right.
Tom
Old Dec 22, 2006 | 10:51 AM
Thanks. It was blatantly obvious once I looked at the pic. I took my time on it but missed that detail. It gets cramped under the car and I didn't notice the other terminal.
The1Sun
Sep 7, 2015 10:21 PM
