Sponsored by: CARiD
Simple: How-to Put In Sparkplug?
Old Dec 17, 2006 | 08:51 PM
ScottyBaby's Avatar
Hello,
As a practical and not-so-funny joke, a friend with my spare key has prevented my car from starting. The engine cranks, but does not start. I did some research, and I realize that the 3 reasons for this are; Fuel, Spark, and Compression. He's done this before - to my other car - with the exact same result, so I figure it can't be Compression - a rotary engine doesn't work the same way as a V6, you can't just unplug something to stop Compression, .. right?
In any case, not getting into any details about this "friend", can someone - please - write simple instructions for purchasing the correct type of sparkplug(s) and installing them in the car?
Basically, I would like to walk down to Kragen's or whatever, purchase, pop in, and drive away. I have never done anything like this before, my extent of mechanical experience is limited to changing the oil.
Thanks in advance,
Scotty
Old Dec 17, 2006 | 09:46 PM
flight_of_pain's Avatar
its supposed to do that
i would tell said friend "touch the seven again and you die"
on a side note i think 2nd gen plugs are br8eq-14 or br9eq-14. check the fsm.
unscrew old plug, screw in new plug, make sure plug wires are going to the correct plugs(fsm again)
isaac
Old Dec 17, 2006 | 09:50 PM
JWteknix's Avatar
wow
Old Dec 20, 2006 | 02:09 PM
archangelkn's Avatar
Talking
Wow, some friend... That's kind of an amusing prank though.
Now for some payback. Personally, I'd cut up some fish into tiny chunks, and put them someplace inaccessible, or at least hidden. Maybe his heat/air conditioning intake vents?
*cackles*
Old Dec 20, 2006 | 02:23 PM
AWD-RWD racer's Avatar
http://www.fd3s.net/ignition_install.html
Old Dec 21, 2006 | 11:35 PM
Sgt.Stinkfist's Avatar
premix, for f's sake
first off, i dont think he changed youre plugs, so buying new ones probably wont make it start. i say check youre under hood fuses, mainly the EFI one, with out that no fuel. then check plugwires/coil wires, look for anything unplugged. if youre buddy knows that you dont have much car experience, he probably did something simple and/or obvious.
Old Dec 26, 2006 | 07:47 PM
NJGreenBudd's Avatar
rx-for-my-7
thats mean of him. geeezzz.............
Old Dec 27, 2006 | 02:17 AM
mightymite's Avatar
put some antiseize or grease on the threads on your spark plugs when u install them
Old Dec 28, 2006 | 02:22 AM
Wargasm's Avatar
Weird Cat Man
Probably did not mess with the plugs themselves since they're kinda a bitch to get to.
I would check that the plug wires are plugged onto the coil packs as well as all the fuses under the hood.
Old Dec 28, 2006 | 01:45 PM
BASTARD's Avatar
If your car stinks of gas, then it is flooded. Hold gas pedal to the floor and crank until it starts... 10 seconds or so then let rest (to let the starter and battery cable cool down) and try one more time.
If you need spark plugs then there are two sets in your car. Leading plugs and Trailing plugs... this is indicated by a "T" or "L" printed on the plug as well as a "T" or "L" cast into the aluminum housing next to the park plug hole. Each housing has one of each
Old Jan 2, 2007 | 03:27 AM
fendamonky's Avatar
F'n Newbie...
^ So... I just got my 7 a couple weeks ago and I am about to put in the PFC. I'm thinking I will be giving her an oil change and fresh plugs/wires before I do the install (just to be on the safe side)
I realize there is a difference in the lead plug and trailing plug irt location and timing of fire. Is there any *physical* difference in the plugs themselves though? Can I go out and pick up 4 NGK Plat plugs and just swap them in for the old ones, or is there a difference in the plugs themselves from leading to trailing?
I have searched.
Thanks,
Levi
Old Jul 18, 2007 | 08:45 AM
dougiepants's Avatar
Which housing does the Leading/Trailing 1 & Leading/Trailing 2 go to?
Old Jul 18, 2007 | 08:50 AM
PinkRacer's Avatar
Licensed Zip Tie Mechanic
I have searched.
Thanks,
Levi
The plugs actually have an L or a T on them, so they're meant to be a leading or trailing plug. They look different than any plug I've ever seen, so no just any old NGK Plat plug will work, these are meant for the rotaries. We've always had to order ours in.
Here's a pic of what they look like:
Old Jul 18, 2007 | 08:51 AM
PinkRacer's Avatar
Front housing top = T1
Front housing bottom = L1
Back housing top = T2
Back housing bottom = L2
FührerTüner
Sep 20, 2015 01:07 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
armans
Sep 6, 2015 09:02 PM
