is 215 too wide for a 6 1/2inch rim?
Old Dec 17, 2006 | 10:21 AM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
I got a rim here that is a 15 inch with a 6 1/2 width. Im trying to see what optimal width tires can I put on. Would this make the tires perpendicular to the road with 225?
Old Dec 17, 2006 | 01:33 PM
Black91n/a's Avatar
Hunh?
Yes you can put 225/50/15's on a 15"x6.5" wheel. It's not ideal (works better on a wider wheel), but it'll work.
Old Dec 17, 2006 | 04:16 PM
So is 215 the widest I can go while still having the tire wall as straight as possible?
Old Dec 17, 2006 | 04:45 PM
Black91n/a's Avatar
If you want straight sidewalls something like a 185 or 195 will be better, but if you want grip the 225's will be better. There's not much available in 215's.
Old Dec 17, 2006 | 11:34 PM
rotarybeat1287's Avatar
Visual Kei
im running 225/50 on the rear, and 205/50 on skyline GTS-T wheels. im pretty sure they are 16x6.5. i love how it grips in the *** end. it handles great and i love the way it feels turning in. i got fresh yokohama's all round as well.
Old Dec 18, 2006 | 09:06 PM
maxcooper's Avatar
WWFSMD
The best answer to this question is to consult the spec sheet for the specific tire, in the specific size that you are considering. Tire Rack has the spec sheets online. Here's an example (215/60-15 Yokohama ES100):
http://www.tirerack.com/tires/Spec.j...e1=yes&place=3
Rim width range: 6-7.5
That means that this particular tire, in this particular size, is approved for use on 15x6.5" rims.
Remember: It varies from tire to tire, and it varies by the size and aspect ratio. Be sure to look at the right line in the right spec sheet.
-Max
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
Rotary12Ahead
Oct 29, 2015 03:16 PM
NickNac113
13
Oct 1, 2015 09:25 PM
