Power FC Power Fc wont give out any spark
Old Dec 16, 2006 | 06:13 PM
XxJaPxOxNeEs23xX's Avatar
i have a 93 7 and had a power fc. i currently just replaced it with the stock ecu because the power fc suddently stopped working, giving no spark to any of my spark plugs. i have changed my ignitor, thinking that it could have caused the problem, but it was not. so, like i have stated, i changed it back to the stock ecu, which only allows me to start it, flooring it or driving it is impossible. the car starts backfiring or lags in the process of raising the rpms. if anyone can help me out with any info, otherwise i might have to save up for another ecu. thanks.
Old Dec 16, 2006 | 09:28 PM
GARCO MOTORWORKS's Avatar
If the crank angle sensors on the front of the motor are gapedto far away from the crank angle sensor plate the power fc will not read the pulses ,but the stock ECU can read the weaker single .The clearence should be.039-.078 in . The closer the better and be sure the plate,wheel is running true .Put shims behind the sensors to get them as near to the wheelas you can .do not let them touch .
Old Dec 18, 2006 | 03:04 AM
thanks for the response; but the car was running before, can the gap change suddenly like that?
Old Dec 18, 2006 | 08:49 AM
Mahjik's Avatar
Mr. Links
What mods are on the car currently?
Old Dec 18, 2006 | 09:03 AM
The car did not change ,but a large clearance will keep a Power FC from running .hard to find the correct fix from so far away .
Old Dec 18, 2006 | 12:45 PM
Eggie's Avatar
Garfinkle, OP states that he was running on the PFC previously. Something must have changed.
Old Dec 19, 2006 | 03:08 AM
my cars pretty much stock. i have just rebuilt it with 3mm seals, hks ignitor, street ported and that basically it; otherwise strait pipe and all that other crap that everyone does.
Old Dec 19, 2006 | 03:13 AM
may i also say that all the sensors seem to still be working that the pfc picks up on the commander, but i am to believe that the pfc itself is broken.
Old Dec 19, 2006 | 12:34 PM
DaleClark's Avatar
RX-7 Bad Ass
PFC's VERY rarely go out, unless something Way Bad happens, like a short in the wiring harness or something. If nothing else, throw in a stock ECU and see if the car will run.
It could be any number of things - damaged wiring harness, bad coils, bad plug wires or plugs, damaged wiring to the crank angle sensors, something fell into the main pulley and bent the trigger ring for the crank angle sensor so it won't pick up a signal.... You just have to troubleshoot on down the line.
Dale
Old Dec 19, 2006 | 01:36 PM
ok cool thanks.
Old Dec 20, 2006 | 10:14 AM
woundup7's Avatar
The Outsider
Sound like my S-5 turbo, when the electric omp went out. Sent the car/ecu into limp mode. It will start up and idle fine. But basically you can't rev it up or drive it with any speed. Oh yea it also fried the ecu.
Old Dec 29, 2006 | 12:23 AM
Lol Garco you were right. dang so happy right now. i tried doing what you suggested about putting the sensor closer to the plate, but then i found out that the crank bolt that held the center main pulley was coming loose, and the gap was too far apart. Thank you guys so much. damn happyness
Old Dec 29, 2006 | 09:36 AM
cewrx7r1's Avatar
Eye In The Sky
So it ends up being engine assembly error.
Skeese
65
Mar 28, 2017 03:30 PM
alphawolff
Nov 17, 2015 05:57 PM
