hHKS hiper suspension
Old Mar 8, 2002 | 06:48 PM
IgoSlow's Avatar
Exclamation HKS hiper suspension
Is 1550 a good deal shipped for these bad boys, and how are they as far as daily driven goes?
thanks
Old Mar 8, 2002 | 10:50 PM
IgoSlow's Avatar
anyone have an opinion on this?
Old Mar 8, 2002 | 10:57 PM
GoRacer's Avatar
Speed Mach Go Go Go
Theres two models
Theres two models and two prices but if you PM RotaryKnight he could tell you since he uses them.
Old Mar 9, 2002 | 11:28 PM
IgoSlow's Avatar
thanks
Old Mar 10, 2002 | 12:42 PM
RotaryKnight's Avatar
The ride can be a little rough at times due to the upper pillow ball mounts. But the suspension is 38 way adjustable from stiff as a solid bar to softer than stock. I daily drove it for a while on LA streets but then again I don't mind a rough ride.
Becarful when you install the suspension. After I installed mine HKS had to change the US instructions. The rear suspension the nitrogen stem has to face the car not the wheel.....
The original Japan instrustions says it in Japanese with a ity bity picture....if you install it wrong the nitrogen stem will hit the lower arm and break off causing all the gas to escape.
The US instructions now comw with a BIG picture!.
Do not buy the HKS Hiper Drag suspension unless that is all you are going to do with the car. The valving is different on it and it makes your rear squat then very slowly rise as you drive. Not good for the street or for autox.
Postman09
Sep 29, 2015 11:23 AM
