Tire sizing help
Old Dec 7, 2006 | 11:55 AM
Fattony's Avatar
Tire sizing help
I want to know if 215 will fit on an 8" wide rim. and also if a 245 will fit on a 9" rim will they fit fine or will they be stretched abit let me know.
Thanks
Tony
Old Dec 7, 2006 | 12:35 PM
Black91n/a's Avatar
Those tires will fit, but a better match would be a 225 on an 8" wheel, this combo gives fairly straight sidewalls without being stretched at all, a 255 on a 9" should give about the same effect (same amount of difference between tire and rim width).
When I put my 225/45/17 shod 17x8's on the ground lying flat on their faces the rim lip/bead/whatever you want to call it touches the ground ever so slightly.
Old Dec 7, 2006 | 02:04 PM
Fattony's Avatar
so would 215 be stretching it too much or would it be fine.
Old Dec 7, 2006 | 02:08 PM
rynberg's Avatar
For most tires, an 8" wide wheel is the widest recommended for a 215, a 9" wheel is the widest recommended for a 245.
Old Dec 7, 2006 | 02:52 PM
gracer7-rx7's Avatar
needs more track time
You could probably go with an 8.5" wide rim with the 245 and save some money and have a lighter rim.
I have 9" wide rim with 255s and they fit well. I would think the 245 might be a bit stretched on my wheel.
Tire Rack's site has some good info on recommended tires/wheel widths.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
rx7jocke
72
Jun 17, 2016 03:48 AM
