Canadian Forum Canadian users, post event and club info here.
good place for a rear end rebuild?
Old Dec 3, 2006 | 07:54 PM
highwayinthesky's Avatar
hey all, just like the title says, a good place to get the rear end of my 87 turbo rebuilt in calgary. also what is the price range for this, i know it depends on the condition and what not but could i get a best and worst case price?
thanks alot
Old Dec 3, 2006 | 09:54 PM
Leigh Adams's Avatar
Struggles with Idling
I had my 84 GSL-SE Limited slip diff rebuilt with new shims etc. for $800 I think. that's from a place in Ontario.
depending what you want to do with the car, you might be able to find a decent used one for a few hundred and just switch the whole rear end. they should be good for almost 200K kms unless you're doing lots of track stuff with it.
hope this helps
Leigh
Old Dec 3, 2006 | 10:41 PM
i will be beating up on the rear end pretty good. the car is a street car for "fun", dont think it will see much track time. a ford 5.0l will be under the hood so a lot more torque will be running through it. all i think i will need is a stock rebuild, could any tranny shop do this?
Old Dec 3, 2006 | 11:19 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
what kinda tires are you running, and how much torque?
Auto or standard trans?
Old Dec 3, 2006 | 11:33 PM
well i havent built the motor yet but it will be a 302 ford with afr heads cobra manifolds and lots more, i think about 350ish whp not too shure on torque yet. the tranny is a t5 out of a 89 mustang(the tranny is the weak link in the setup but i have looked it over and driven it as well, i have never ran the diff so i want to be shure it dosnt come apart) as far as tires not shure yet, the car is still in project/build up stage but i am trying to take care of as many lose ends and potental problems as possible and the diff is right now one of the biggest time bombs i could see.
Old Dec 4, 2006 | 09:40 AM
01Racing's Avatar
Go Hard....or Go Home
Have you thought about swapping in the center section of a Lincoln Mark VIII? They are aluminum 8.8's I think!
Old Dec 4, 2006 | 10:12 AM
not really, is a mark viii a solid axle? if so i dont want to do it.
some one must have had there fc rearend rebuilt in calgary, send me in the right direction
