G35 WHEELS fit FD3S?
Old Nov 23, 2006 | 02:47 AM
jef57's Avatar
Question G35 WHEELS fit FD3S?
Hello,
is these wheels fit fd3S?
G 35 infiniti wheels, 18X8 ET 30
i don't know center bore of these wheels.
could fit ?
Thanks for your help
Jef
Old Nov 23, 2006 | 02:50 AM
NeedFD's Avatar
R. R. R.
offsets will not work on an fd, maximum you should go is +35 to be safe any less youll have rubbing issues
Old Nov 23, 2006 | 02:57 AM
VegasFD's Avatar
Wishin I Still Had The FD
Those wheels would look terrible on an FD anyway. Leave them alone.
Old Nov 23, 2006 | 04:23 AM
Advent7's Avatar
PCD is 5×114.3 this is the 350Z pcd and thats the same as the G35.
Like NeedFD said make sure you get the right offsets unless you want to be rolling your fenders.
For my Z I bought 19"×10.5" and 9.5" offsest were +17 and +18 and the rears rubbed. If your also slammed (lowered) then u might want to think about the right offsets.
I don't know much about FD's but 18" by 8" with a +30 offset can rub? Thats only 5mm over the the recommended.
I know cars are different but for my car the offsets should have been 32-36 and I'm 15-19mm off and I barely had to roll my fenders.
Old Nov 23, 2006 | 07:23 AM
jef57's Avatar
and for center bore?
FD (67,1MM)
G 35 ???
350Z ??
THANKS
Old Nov 23, 2006 | 09:36 AM
Unholy FD3S's Avatar
Im a dog, I love hoes
yea i really dont think they would look good, someone should do a photochop
Old Nov 23, 2006 | 10:01 AM
FDNewbie's Avatar
Sponsor
FD OEM offset is +50 all around. You can get away with about +37 in the front w/ occasional rubbing on the fender lining on OEM STOCK RIDE HEIGHT, but you'll run into clearance issues w/ an aftermarket suspension.
For the rears, around +40 is as far as it'll go, again with OEM STOCK RIDE HEIGHT.
Of course, these #s change based on the width of the wheel. I'd consult this post for some nice offset ranges: https://www.rx7club.com/showpost.php...61&postcount=8
~Ramy
PS: I agree, those rims would look VERY bad on an FD. We've seen many examples of rims like those posted up on the forum...
Old Nov 23, 2006 | 12:58 PM
rynberg's Avatar
They won't fit. Question answered.
fidelity101
13
Aug 31, 2015 07:47 PM
