everyone please
Old Mar 6, 2002 | 08:48 PM
perfect7's Avatar
everyone please
what does you oil press gauge read at idle and highway cruise, lets say 55-60 mph. I want to see what the average is.
Old Mar 6, 2002 | 08:55 PM
rico05's Avatar
WTB S5 N/A FC
About 50psi on mine. When I punch it, like almost 60 psi. At dead idle, 30-35 psi.
Old Mar 6, 2002 | 08:59 PM
jeff_oner's Avatar
mine sits about 30 at idle, and around 60 when driving.
RestoTII's Avatar
when it's warmed up, it reads about 5 psi constantly. Had it checked and they said its puting out 8psi at idle, probably 10psi under acceleration, but they told me not to worry.... so.....
Old Mar 6, 2002 | 09:03 PM
xiaomingming50's Avatar
u sure that's not boost? wow weird
anyway, mine's 30 idle 60 warmed up and 3k+ rpm
Old Mar 6, 2002 | 09:05 PM
Icemark's Avatar
idle around 35
highway around 60
Old Mar 6, 2002 | 09:12 PM
InfiniIIIREX's Avatar
Mine is the same as ^^^^
Old Mar 6, 2002 | 09:47 PM
Scott 89t2's Avatar
SOLD THE RX-7!
umm... I think it's time to worry...
Old Mar 6, 2002 | 10:42 PM
My engine runs a tad over 60 PSIG at anything over 3K RPM. At idle I run 18 PSIG. The low idle pressure is because I modified the oil jets in the e-shaft when I rebuilt the engine. Instead of the check ball and spring there I have a plug with a 2MM hole drilled in it. If I had it to do over again I would not mod the e-shaft unless I was going to run the engine at high speeds for long periods of time, like for racing or aircraft use.
Old Mar 7, 2002 | 12:57 AM
Taranis's Avatar
when mine's working right it's 30 @ idle and 55-60 at 3000 RPM. I gotta get under there and start checkin' wires... dammit.. :<
JB
