Battery problem...
Old Nov 14, 2006 | 07:26 PM
crazyasu's Avatar
Angry Battery problem...
car won't start after sitting for hours...turns over a couple times then dies...fires up right a way if I jump it...seems to hold a service charge if I take for a drive...shut er down...leave it for an hour...it'll start right up...battery reads 13.09V with a DMM...could be bad cells...??????...cold weather...time for a new battery...
Old Nov 14, 2006 | 07:45 PM
Turbonut's Avatar
First, it would be best to have the battery tested, and make certain the alternator is good. If both prove to be good, check for a draw when the ignition is off. You can disconnect the battery and let it sit until the next use, and if it starts fine, then there must be a draw.
Disconnect the negative terminal and do a test with an ammeter. Geez, I recommended using a 12 volt light to check for draw as some don't have a MM, or aren't familiar with amps, and got my head handed to me, so once again use an ammeter to check for a draw. The normal current drain on most vehicles should be about 25/75 milliamps or less. If the key-off drain exceeds 75 milliamps, there’s an electrical problem that requires further diagnosis. Start pulling fuses until you reach the circuit when the meter drops and continue from there.
Old Nov 14, 2006 | 08:06 PM
liv's Avatar
liv
New User
also might wana replace your terminals
it might be as simple as that
at least it was for me last winter
Old Nov 14, 2006 | 08:08 PM
Sideways7's Avatar
I bet you just need a new battery. You can take it to pretty much any auto parts store and they will load test it to make sure.
Old Nov 15, 2006 | 12:35 AM
crazyasu's Avatar
problem solved...sticky door handle causing ignition light to stay on thus draining battery...
Old Nov 25, 2006 | 12:28 AM
dole2000's Avatar
battery terminals can manifest into so many wierd issues. Always have to keep after them. Our cars are around twenty years old. Seems like old wires get you more than mechanical issues.
FC3S Timmy
16
Oct 3, 2015 01:08 AM
FC3S Timmy
Oct 2, 2015 08:08 AM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
Devon Murray
Sep 25, 2015 09:41 AM
