Need to get new tires for Vert BBS rims - q on sizing
Old Nov 14, 2006 | 09:22 AM
STR8BALLIN - R's Avatar
Should i replace with the stock size 205 60r15 or can I step up to a 225 60 15 with no problems?
need to cost some out asap so help is appreciated
Old Nov 14, 2006 | 09:44 AM
Black91n/a's Avatar
225/60/15's are taller than stock, you may run into rubbing problems, and the speedo will be off and you'll accelerate slower. For performance summer tires, get 225/50/15's, they'll lower the gearing a bit for better acceleration, lower the car slightly for better cornering, and will have better options for tires. For winter tires (since we're heading into winter), you want narrower tires, stick with stock or maybe a 195/65/15. The narrower tire cuts through snow better to get to the pavement below.
Akaviri
Sep 9, 2015 03:56 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
