Timing for ported Engine
Old Nov 13, 2006 | 07:24 PM
jazzmanbob's Avatar
Rotate or go home!
Need to know if the ignition timing needs to be adjusted different from stock on a ported non turbo. It is an 88 with lightened rotating assembly and new turbo housings. Racing beat headers, bonez hiflo cat and unknown cat back.
Right now I have it set with the yellow mark spot on the marker. Since port timing is changed by the porting does the ignition timing have to be changed to match?
Thanks
Old Nov 13, 2006 | 11:13 PM
Sideways7's Avatar
As long as its a streetport you can keep the same timing. My car with a large streetport ran with stock timing and did great.
Wolf_
Aug 11, 2015 04:23 PM
