Severe overheating
Old Nov 13, 2006 | 02:52 PM
eviljoel's Avatar
Severe overheating
i just got my rx-7 put back together (for the most part) but im afraid to drive it now. reason being last night it was like 50 degrees out and i was running it trying to fix the gauges. All was well i idled it then about 30 mins into it HUGE amounts of steam start spewing out of the recovery container's T valve. no lines are broken and the engine didnt lose compression (thank god). but now im rnning around in the dark can some 1 plz help me out. Thank you
Old Nov 13, 2006 | 03:46 PM
stevej88na's Avatar
Strength and Honor
If it's a new rebuild, it may have air bubbles in the coolant lines somewhere. Those can stop the coolant flow, especially if they get caught at the water pump. Check the CSM for a good filling method:
http://howto.globalvicinity.com/gv_w...i=91&co=1&vi=1
Old Nov 13, 2006 | 04:50 PM
HAILERS's Avatar
HAILERS
OPTIMIST
Old Nov 13, 2006 | 05:44 PM
arghx's Avatar
rotorhead
you need to do a coolant seal check
Old Nov 13, 2006 | 06:22 PM
eviljoel's Avatar
phew
when i get back im going to bleed the coolant system. as for the coolant seals faultering, there is no other symptoms like exhaust smoke, power loss, leaking. The engine dosent have a lot of time left in my rig because im getting a 13b turbo. then ill rebuild that one. im also checking my thermostat since we recently replaced it. Mabye i got one that opens up at a hotter temp. there has got to be other things ill be schecking with a lot of scrutiny, the water pump, the hoses, even the new radiator. thanks for your help yalls ill report back if i fixxx it
Old Nov 13, 2006 | 06:27 PM
eviljoel's Avatar
also i failed to mention before we did this we flushed the coolant system
Old Nov 14, 2006 | 05:12 PM
eviljoel's Avatar
i burped the coolant system and its running much better, but i ran across a leaky coolant seal that i gotta rectify ill take a trip to the auto parts store whom prolly know me on a name by name basis.
Old Nov 14, 2006 | 05:17 PM
Stanis's Avatar
The only kind to use is Mazda OEM t-stats. Did you use another kind?
JoesFC
Oct 5, 2015 08:10 AM
cooldude
West RX-7 Forum
Oct 3, 2015 09:17 PM
Devon Murray
Sep 25, 2015 09:41 AM
The1Sun
Sep 18, 2015 07:13 PM
erevos
Sep 15, 2015 09:19 AM
