Snowperformance..... AI Vendor
Old Nov 12, 2006 | 08:30 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
Snowperformance is a major player in AI and should absolutely be looked at. They generally use a 50/50 mix of alcohol and water. Snow has a progressive controller, a very interesting failsafe device that measures flow and cuts of whatever you wish if the flow drops below a certain level. Ford's SVT ONE Lap car used the Snow AI setup and had to detune for the road course portion as it was shredding it's tires... check them out.
colorado 719 633 3811
http://www.snowperformance.net
howard coleman
Old Nov 17, 2006 | 08:15 PM
the december issue of Hot Rod has a one page article on a supercharged 2004 ZO6 Corvette using a Snowperformance water/methanol AI kit.
91 octane. yuchh.
AI, yippie.
an interesting tuning session.
without AI at 10 psi boost, the ECU allowed 14 degrees advance, at an AFR of 12.2-12.5. hp was 585.
with the AI initiating at 3 psi the computer allowed 24 degrees advance at 12-12.25 afr and made 640 rwhp at the same boost!
Snow's Safeinjection module was employed to trigger a blowoff valve in case of low flow...
nice writeup. nicer results.
howard coleman
