Megasquirt VR Conditioner Pot Resistances?
Old Nov 12, 2006 | 10:42 AM
Aaron Cake's Avatar
Engine, Not Motor
Can anyone tell me the resistance of the two pots with their wipers turned fully counter clockwise? I checked the datasheet (http://www.vishay.com/docs/51025/t9.pdf ) but it does not indicate at which side of the travel the end resistance is measured.
Thanks!
Old Nov 12, 2006 | 11:57 AM
muythaibxr's Avatar
MegaSquirt Mod
If I remember correctly the hysteresis pot is 100K when fully counter clockwise.
I can't find anything for the zero crossing one, but it's probably fully 10k (0 v zero crossing).
Ken
Old Nov 12, 2006 | 04:20 PM
Aaron Cake's Avatar
Engine, Not Motor
That makes sense. The damn things don't have much of a "stop" on them so it's easy to turn them way past where they should be...
Old Nov 28, 2006 | 08:51 AM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
if you listen or feel very carefully you'll hit the clutch, you can feel it clicking.
Then just go backwards from there? I guess.
They seem to have quite a few turns of travel, I just turned mine up as far as possible before I didn't seen RPM's at cranking, then back 1/4 turn and it seem to have eliminated all of my noise issues except at super high RPM's, where there is still a little noise that I can't track down.
BLUE TII
Sep 26, 2015 10:12 PM
whinin
Sep 23, 2015 04:09 PM
localized
Sep 16, 2015 12:18 AM
