Racing Beat Aluminum Side housings
Old Nov 10, 2006 | 07:38 PM
crispeed's Avatar
'Tuna'
http://img204.imageshack.us/img204/4712/allthreealumhouseou6.jpg[/img]
Old Nov 10, 2006 | 07:47 PM
R.P.M.'s Avatar
Likes to swear....alot
I want a set of those....but the bank didn't have enough money in their vault at the time LOL.
Old Nov 10, 2006 | 07:49 PM
crispeed's Avatar
'Tuna'
Just take out a second mortgage!
Old Nov 10, 2006 | 08:46 PM
IAN's Avatar
IAN
Rotary Reborn!
is it true that they barely even sold a set?
Old Nov 10, 2006 | 08:50 PM
now's Avatar
now
never noticed before, need a few extra bolts for the front and rear gears.
since i cant afford bolts i guess i will cancel my order for those housings.
matt
Old Nov 10, 2006 | 09:29 PM
crispeed's Avatar
'Tuna'
matt
I can get you a good deal on the bolts. Better yet let's do a group buy!
Old Nov 10, 2006 | 09:46 PM
kuroi FD's Avatar
Im all about these housing for lightness purposes but arent they made out of iron because its dispells heat quickly? wouldnt you be overworking our coolant system? How much is a set couldnt find it on the site...
Old Nov 10, 2006 | 09:55 PM
user 893453465346's Avatar
Red Pill Dealer
Iron has crappy thermal conductivity. But good absorbtion.
Old Nov 10, 2006 | 09:56 PM
Mahjik's Avatar
Mr. Links
Average of about $1400 per plate (less for the front, more for the inter, and then in the middle for the rear IIRC).
Old Nov 10, 2006 | 09:57 PM
R.P.M.'s Avatar
When I called them about these a couple months ago, they would sell me the front and center iron.......but they didn't have the rear available yet.
I guess they have the rear one figure out now.
I believe it was roughly $4000-4500 US for the whole set without side ports milled into them.
Old Nov 11, 2006 | 02:28 AM
RXBeetle's Avatar
Not to mention they would wear like mad. Stock irons are 60+ HRC hardness, aluminum is soft as hell and makes a **** poor wear surface. Now with some ceramic coating now that's a different story... Otherwise That $4000-$4500 would quickly becomes coffee table art. You better be makin some big money racing to justify spending that much on a "disposable" part or spend even more to have them coated with some slippery coating.
Old Nov 11, 2006 | 12:31 PM
BLUE TII's Avatar
Rotary Motoring
They are ceramet coated.
Cost is the only reason Mazda stopped using Aluminum in their production engines after the Cosmo Sport (first rotary). They still used aluminum side housings in there race engines.
Before ceramet coatings they used flame sprayed high carbon steel.
Old Nov 11, 2006 | 07:16 PM
ErnieT's Avatar
Living life 9 seconds at a time
Chris,
What are some more advantages to these. I may get them over the winter if you think it would help alot. TIA....
Ernie
Old Nov 11, 2006 | 07:21 PM
Red Pill Dealer
It also appears you would need to drill oil passages for the pump. Look at the pic.
Old Nov 11, 2006 | 09:17 PM
now's Avatar
now
for what they charge i would think they would be drilled!
Old Nov 11, 2006 | 11:21 PM
C. Ludwig's Avatar
www.lms-efi.com
Nope. Sure didn't.
Attached Thumbnails Racing Beat Aluminum Side housings-pict0012.jpg   Racing Beat Aluminum Side housings-mazda-mf1.jpg
Old Nov 12, 2006 | 10:27 PM
BLUE TII's Avatar
Rotary Motoring
used
The aluminum sidehousings from the production Cosmo Sport 10A were used in factory racing 10A engines whether in a Cosmo Sport or the 10A powered R100 and RX-3s that were produced with the cast iron sidehousings.
If there was an advantage to using cast iron sidehousings they would have used them.
BLUE TII quote- They are ceramet coated.
Was in response to
kuroi FD- Im all about these housing for lightness purposes but arent they made out of iron because its dispells heat quickly? wouldnt you be overworking our coolant system?
Old Nov 13, 2006 | 04:57 PM
FDNewbie's Avatar
Sponsor
Just thought I'd chime in and mention that there's already a thread about these badboys from '03: https://www.rx7club.com/20b-forum-95/rb-aluminum-side-plates-238179/
~Ramy
Old Nov 13, 2006 | 08:25 PM
RX-Heven's Avatar
I'll blow it up real good
I've been dreaming about those forever.
No turbo oil feed passages. Couldn't be too hard to drill for one of those...now where did my Makita go?
What I would be worried about is the strength of the dowell areas. They look to be about as thick as S5-S6 housings. Perhaps they were intended for non-turbo/low hp cars.
I hope ErnieT will be the Guinea Pig.
Old Nov 13, 2006 | 10:53 PM
FDNewbie's Avatar
Sponsor
LOL. Man oh man could that be an expensive mistake...
Well I know that at higher rpms, the major concern is housing flex, so I'm not sure how good of an idea these aluminum housings are... ?
+1. Ernie tries everything
Old Nov 14, 2006 | 06:22 AM
ErnieT's Avatar
Not this time!
Old Nov 14, 2006 | 04:14 PM
astrochild7's Avatar
controlled kaos
I can happily say that I'll be purchasing them with in the next year, if avaliable... I 've been drooling over those and other new ceramic advances with full doweling for years... I'll bee contacting racingbeat soon to see if any are avaliable,and to make sure mid-plate can be milled to except roller bearing/2piece eccentric Have plans for a future motor build...wicked kiwi-re short block 4 rotor all plates aluminum, full doweling, dry-sump, ceramics 30+psi yadaayadda... basically my midlife crisis motor build with a 50g price tag.... these toy's are what have driven me to succeed/ make money piles of it... now just feeding the priorities.. in due time....
Old Nov 15, 2006 | 01:18 PM
crispeed's Avatar
'Tuna'
The dowel area are the same size as the FD's. Plus depending on the technique used in casting and type of aluminum used it can be much stronger than the cast iron used by Mazda.
Old Nov 15, 2006 | 07:58 PM
mono4lamar's Avatar
In the burnout box...
man i wish i could snag a sponsor one thing to think about would be the wear on these housings. those things look sooo sweet! i love how they put the rb in the front plate
cristoDathird
28
May 30, 2019 08:47 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
