Good idea to use fuel additives?
Old Mar 5, 2002 | 08:02 PM
AZ85RX7's Avatar
Question Good idea to use fuel additives?
Two questions:
1)My car needs to pass emissions this month, what should I do to get it ready? Also, is it a good idea to put that "pass emissions" fuel additive in it?
2)When I finally get this thing on the drag strip, would it be ok to use an octain boost additive and 92 octain gas?
Thanks!
Old Mar 5, 2002 | 08:15 PM
4ohfour's Avatar
*thanks god he lives in alberta canada*
emissons control board - "hey earl, you ever seen one o' dem wankel engines!?! i hate comunism, and i hate dems engines too a'huk!"
Ask the guys at the track what they use, I am sure you'd get some helpful advice from them. I'd asume that adding an octane booster to 92 octane gas would yeild some marginal results maybe getting you to 95 - 97 but nothing any higher (i could be wrong here though). Best bet would be to ask around and see what others use.
cheers'
Old Mar 5, 2002 | 09:14 PM
jimmyv13's Avatar
Round&Round not Up&Down
Re: Good idea to use fuel additives?
Originally posted by AZ85RX7
Two questions:
There is stuff out there that guarantees you pass an emissions test.... they sell it in AutoZone. I've never used it, though. Search on the forum, there have been other threads about this.
Thanks!
Rotaries run better on lower octane.
Old Mar 5, 2002 | 09:19 PM
smnc's Avatar
EliteHardcoreCannuckSquad
jimmyv13 is right. 87 octane or even a bit lower is ideal for rotaries, unless they are turbo'd or supercharged, of course.
Old Mar 5, 2002 | 09:20 PM
Montrealer's Avatar
octane is in the fuel to prevent it from igniting before the spark plugs fire (detonation)
Racers use high octane fuel to prevent this from happening because they ether run high boost or have a high engine compression ratio. In your case, unless the above aplies to you, its gonna give you nuthing at all and theoreticaly makes your fuel harder to burn.
Old Mar 5, 2002 | 09:31 PM
4ohfour's Avatar
well then, my theory was shot to ****, But now i can save some money and fill up with ell cheap'o gas (85 is the lowest at the place that I goto, here i was dumping an extra 10 cents into every litre for 91. For shame..
cheers'
Old Mar 5, 2002 | 09:32 PM
smnc's Avatar
85 will do just fine for a NA engine.
Old Mar 5, 2002 | 09:38 PM
Montrealer's Avatar
cheers'
Unfortunately this happens to be a very common misconception
Old Mar 5, 2002 | 10:22 PM
Pittdp's Avatar
who sells 85, I have only seen it down to 87
Old Mar 5, 2002 | 10:30 PM
jimmyv13's Avatar
Sunoco sells 86, they call it the economy grade
Old Mar 5, 2002 | 10:54 PM
WackyRotary's Avatar
standard combustion
They sell 85octane at upper alitudes due to the lower air density up there, kinda like natural octane boost because thiner air makes the combustion slower. Cars that normally run 89 can go to 87 and cars runnin 93 can go to 89 safely up above 4000ft. With the thinner air at high alitude the the amount of air is ofcourse less and less fuel is used. Thats why engines that make about 100hp near sea-level will make 75hp at 11,000ft because less air is fed in. If your running boost, this doesn't work out the same way ofcourse. ..you just run your normal octane.
Old Mar 6, 2002 | 09:52 AM
cjf's Avatar
cjf
I agree with everyone, go with the el-cheapo gas...save your money ...no additives except for: MMO in the oil and gas...great for rotaries.....cjf..................
Old Mar 6, 2002 | 09:34 PM
smnc's Avatar
I forgot to mention earlier, I passed my emissions, and I used a bottle of the guaranteed emission stuff. Dunno if it helped, but it didn't hurt...
befarrer
Microtech
Aug 22, 2015 05:52 PM
