plugs for SE
Old Mar 5, 2002 | 06:45 PM
hanman's Avatar
plugs for SE
Is it right that the leading and trailing spark plugs are the same? Unlike an SA?
Thanks,
hanman
Old Mar 5, 2002 | 06:50 PM
JoseReyes's Avatar
RicanRider
Re: plugs for SE
If you are using the stock NGK's then both the leading and trailing plugs are the same. If you opt to use the second gen plugs then the Leading and the trailing will be different.
Yes, you can use the second gen plugs on a first gen. I have been using them on my 82 GSL for over three years now. I use the platinum tips..Works great, last longer., go figure....
Fit perfect.....
Thanks,
hanman
Old Mar 5, 2002 | 07:54 PM
smnc's Avatar
EliteHardcoreCannuckSquad
I use 2nd gen plugs too, and I was thinking of switching to the platinums next time. You think they're worth it Jose?
wretchedegg
Nov 19, 2025 03:07 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
betes
Sep 27, 2015 08:25 AM
ZacMan
Sep 19, 2015 09:20 PM
Enzo1944
Sep 6, 2015 08:57 AM
