Oem brake parts?
Old Nov 9, 2006 | 12:08 AM
cooliomo's Avatar
whats that smell!?
Oem brake parts?
what is the break material that the 4piston caliper used stock?, and what is every one else using?
Old Nov 9, 2006 | 12:23 AM
Icemark's Avatar
The stock pads are a semi metallic, however aftermarket pads should based on driving style and conditions more than a type.
For example if you are using the car in a race track you would probably use different pads than a street driven vehicle, which would be different than pads used for autoX
Old Nov 9, 2006 | 12:27 AM
Black91n/a's Avatar
Most street pads are some sort of organic friction material, sort of like clutch lining.
If you want some performance street pads try Hawk HPS, EBC Greenstuff, Porterfield R4S, Axxis Ultimates, or any number of other name brand heavy duty street pads.
You don't want race pads on the street, they're noisy, dusty, they don't work that well when cold and they'll destroy your rotors in no time.
josef 91 vert
23
Sep 3, 2015 11:20 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
