Microtech wacky idle surge
Old Nov 7, 2006 | 02:23 AM
Funkspectrum's Avatar
wacky idle surge
I'm not sure if this is an issue with my microtech or if it's mechanical...
The idle usually holds at about 1k rpms...today it jumped to 1500 and peaked at 2k...
It's freaking me out because the idle isn't droppind to 1k when I hit the clutch.
Maybe stuck primary injectors?
Old Nov 7, 2006 | 08:34 AM
Aaron Cake's Avatar
Engine, Not Motor
Stuck injectors would drown the car in fuel. You would have no idle, and a trail of fuel out the exhaust (if it even ran).
Check for a vacuum leak, or a stuck throttle cable.
Old Nov 7, 2006 | 10:31 AM
ok...thanks aaron..
Old Nov 7, 2006 | 12:13 PM
RotaryEvolution's Avatar
Sharp Claws
could be something hanging up on the throttle arm or it's just sticky, try pushing the throttle closed manually and see if it isn't just sticking.
Old Nov 7, 2006 | 12:23 PM
The Wankler's Avatar
FKITALL
Originally Posted by Karack
could be something hanging up on the throttle arm .
I had that problem before.
Old Nov 7, 2006 | 08:34 PM
rx7theone's Avatar
Tps
I Think Your Tps Mite Be A Litle Off.
Old Nov 7, 2006 | 09:06 PM
meh..it was the nut on the idle adjuster screw. The nut disappeared. I gotta find another one...too bad my other TB is a jspec and has a stripped out screw...
squirrels
Sep 1, 2024 09:52 AM
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
NLPerformance
Oct 2, 2015 07:11 AM
