Fully Built 20B Package for sale
Old Nov 4, 2006 | 07:50 PM
Turbo 3's Avatar
Safety Guy
Unfortunately I need to part with a long-term project I have been working on. All parts listed below have 900 miles on them. This is installed in an FC and the motor brackets come with it for an easy drop in.
20B Package
1 – New complete OEM seal kit with Mazda 1 piece 2mm apex seals
2 – New FD Front rotor housings (all 3). Front used vs. rear to avoid additional emissions ports, front housings do not have any.
3 – New Iron housings (both center segments)
4 – All 4 iron housings faces lapped and brought to close tolerance
5 – All 4 iron housings polished to a 5 RA smoothness finish (near mirror)
6 – New Series 5 FC high compression (9.7:1) rotors (all 3)
7 – Ceramic coating of water pump
8 – Polished throttle body, upper and lower intake manifolds.
9 – New 550 cc primary and 1600 cc secondary fuel injectors
10 – Custom fuel rails (both primary/secondary)
11 – Custom sleeved fuel injector fittings
12 – Custom polished thermostat housing with dual thermostats (160 & 185 deg F) and temperature sensors (x2)
13 – Large street port
14 – Chromium Nitriding to all housings (much greater wear resistance than OEM nitriding)
15 – All emissions ports welded closed (no plugs used)
16 – OMP removed and sealed shut with custom plate
17 – Pulleys are “wide” version for larger belt
18 – Custom alternator tensioner bracket and idler pulley
19 – Throttle body has “TB Mod” done to it (primary butterflies removed, all holes welded shut)
20 – Throttle body TPS (throttle position sensor) has custom boss to use standard GM 3.5L engine TPS. This was done because every time I tried to use a stock Mazda TPS it was bad and the only place to get them is Japan, and it takes at least 2 months to get them. GM parts are cheap and plentiful.
21 – 2 Bar MAP sensor
22 – Lightweight steel flywheel (18 pounds vs. stock 24)
23 – ACT Extreme clutch and 6 – puck pressure disc (900 miles)
24 – Custom 20B motor mount brackets and assembly bolt kit (powder coated gray)
25 – All motor components cryogenically treated
26 – Deburring of internal coolant/oil passages
27 – Custom alternator bracket and adjustment tensioning arm
28 - FD rotor oil control rings
Other accessories included;
1 – Turbonetics T-76 turbo (0.72 compressor P-trim and 1.32 turbine A/R). Turbo has been ceramic coated both compressor and turbine housings. Includes 0.085” oil restrictor pellet
2 – HKS 60mm Racing wastegate. Lower body has been ceramic coated to prevent heat soak. Spring rating is 12 PSI
3 – Custom 20B exhaust manifold with ceramic coating and welded bung for EGT probe in exhaust runner for individual rotor exhaust port temperature indication
4 – A’pexi AVC-R computerized boost controller. Comes with all wiring, sensor, vacuum tubing. Only used for 20B project
5 – Intake polished manifold piping from TB to FMIC. Includes A’pexi dual chamber BOV.
6 – 89-91 TII starter (with 5000 miles)
I'm also willing to sell the EMS with this package, which is an Electromotive TEC 1. It comes with an external crank trigger wheel, coil packs, etc, and I will include the current fuel/ignition map. I've got $3300 for the whole system and would be willing to include it with the motor for a little less than half, $1500.
One issue that I want to address is there is an oil smoking issue that I've had from the beginning. After some R&D have come to the conclusion that it's due to the chromium nitriding coating applied to all rotor and iron housings. It appears that it is creating a longer break in period as other than this, the engine runs very well. Just recently it was given a base map by Steve Kan and made 410 rwhp at 8 psi with plenty of room for more boost, more tuning. We had to stop, however, as I ran into an unrelated electrical issue, otherwise the plan was to go to 15 psi on the dyno. The motor was built to make 600-700 HP as well.
I've got about 30K into this setup with all the custom work, etc, and was looking to get half or 15K for everything listed. If you want the EMS with it, the price would be $16,500. This would be an excellent opportunity for anyone going to do this conversion as most of it is already done for you.
I have a couple hundred pictures available during the entire build as I wanted to thoroughly document it for insurance purposes, for car shows, etc. I will post some on here but if you want anything specific, please email me at ckuehn8171@charter.net and I'd be happy to send you whatever you like.
Old Nov 4, 2006 | 07:56 PM
Turbo 3's Avatar
Safety Guy
Here are some pictures of the engine still in the car. If you would like to see additional pictures of the build, porting, clutch, etc, please email me and I'll be happy to do so.
Attached Thumbnails Fully Built 20B Package for sale-dsc03108.jpg   Fully Built 20B Package for sale-dsc03107.jpg   Fully Built 20B Package for sale-dsc03106.jpg   Fully Built 20B Package for sale-dsc03105.jpg   Fully Built 20B Package for sale-dsc03104.jpg
Old Nov 4, 2006 | 08:10 PM
mcfly's Avatar
nice setup
gl with the sale
Old Nov 5, 2006 | 04:14 PM
Sobr609's Avatar
damn i wish i had a body and 15k..well i could easily get a loan for 15k..but then i would want to get a s5 shell or a fd shell..my s4 i would not use..DAMN..i am interested why your selling..but im not gonna pry into your business..BEAUTIFUL MOTOR..car looks just as good..are you selling the car too or no?..hope your not leaving the rotary game for good..good luck with everything..who-ever gets this will be a lucky man or woman..later
Old Nov 5, 2006 | 05:25 PM
Turbo 3's Avatar
Safety Guy
Not the car, just the engine, etc, as listed. Need the money for bills, etc. The car will probably end up sitting for a few years until I can get afford to do anything with it again unfortunately.
You should be able to get an S4 or S5 TII shell for pretty cheap, 1-2K?
Old Nov 12, 2006 | 03:59 PM
Turbo 3's Avatar
Safety Guy
I'm going to start pulling the motor this week so it can get prepped on the pallet for shipping. Willing to negotiate on the EMS so I can leave it all connected and ready for you to drop in and start it up. It's got a good base map and is ready to run.
Old Nov 21, 2006 | 07:47 PM
Turbo 3's Avatar
Safety Guy
more pics of the assembly, coating, porting, etc.
Attached Thumbnails Fully Built 20B Package for sale-cr2_coating_002.jpg   Fully Built 20B Package for sale-cr2_coating_003.jpg   Fully Built 20B Package for sale-final_001.jpg   Fully Built 20B Package for sale-0140.jpg   Fully Built 20B Package for sale-dsc01581.jpg
Old Nov 21, 2006 | 07:52 PM
Turbo 3's Avatar
Safety Guy
a pic of the iron and coating so you can see the smoothness of the lapping
Old Dec 16, 2006 | 02:03 PM
Turbo 3's Avatar
Safety Guy
Bump ^
Old Dec 16, 2006 | 09:27 PM
justturbo2's Avatar
Registered User
Nice Set Up. Wish I Had The Money. Good Luck Selling.
Old Dec 17, 2006 | 08:07 PM
anderdick88's Avatar
where did u get the exhaust manifold & how much if u dont mind me asking THANKS
Old Dec 17, 2006 | 08:55 PM
Turbo 3's Avatar
Safety Guy
If you want, I will PM you the information but I won't give them any free advertising as they were absolutely terrible to work with and the POS that I received from them had to be reworked with the shop I used to do all the rest of the work on the car. Plus they wouldn't give me my money back and were a-holes for customer service.
Sorry to sum it up that way but it was a bad experience.
Most places should be in the $800 range for a manifold give or take but my suggestion is to have somebody locally do it for you so you can see what you're paying for and make sure it fits right.
Old Dec 17, 2006 | 08:56 PM
mirabile's Avatar
best of luck, looks beautiful. PM me if your interested in parting anything.
Old Dec 17, 2006 | 08:57 PM
Turbo 3's Avatar
Safety Guy
I will also include the spare plug wires and ceramic spark plug boots for the coil packs to the plugs when you purchase the package with the EMS.
Old Dec 20, 2006 | 05:07 PM
Turbo 3's Avatar
Safety Guy
Open to offers on parts combinations but will not take apart the long block. Selling turbo/exhaust manifold, etc, combo on another thread as well.
https://www.rx7club.com/showthread.php?t=607198
Let me know what you want, PM me, and we can talk.
Old Dec 23, 2006 | 01:54 PM
520hp@26lbsRX-7's Avatar
Bosozoku
You have everything to convert to a 20b? Everything and It will run fine?
Old Dec 23, 2006 | 02:18 PM
Turbo 3's Avatar
Safety Guy
That depends upon your definition of "everything". You will still need a engine cradle (mine is for a FC, FD's require a different adaptor), larger radiator, fuel pump, and exhaust for starters, which you will need to do on your own.
The "package" has everything else you need to drop it in and turn the key besides those things. This also includes a running base map that was dyno tuned to 410 HP at 8psi.
I'll PM you my phone number if you have more questions.
Old Dec 26, 2006 | 11:59 AM
Turbo 3's Avatar
Safety Guy
Looking to get $10,500 shipped for the long block (includes polished intake manifolds, flywheel, polished TB with TB mod, GM TPS adaptor (you don't need to use junk Mazda TPS and it uses a standard GM V6 TPS which are plentiful and cheap), fuel injectors (550 primary and 1600 seconday), ceramic coated water pump). Does not include clutch, turbo, exhaust manifold.
Has all new rotor housings, rotors, both center irons are new, all irons have been lapped and all housings chromium nitride coated inside and out. New seal kit (rings and metal seals) and large street port. All the aluminum has been polished and the water pump and front cover have both been ceramic coated as well to help prevent heat soak.
Would like to sell the EMS with it and it is already wired and ready to go, just hook up the connections. EMS alone is $3300 with the crank trigger wheel. Also includes the coil packs, spark plug wires, and ceramic spark plug wire boots. Comes with fuel/ignition map as well that I will email you so you can plug & play. Price with the long block is $12K shipped and insured.
Old Dec 28, 2006 | 04:49 PM
hey turbo3 waiting for ur reply for the manifold
Old Dec 28, 2006 | 06:40 PM
Turbo 3's Avatar
Safety Guy
FC exhaust manifold sold
Still have wastegate, turbo, BOV and boost controller available. Would be perfect package for FD 20B owner as the FC manifold would not fit an FD regardless.
Old Dec 30, 2006 | 10:26 AM
Turbo 3's Avatar
Safety Guy
Pipe and BOV, TEC 1, and coils with ceramic boots/plug wires
Attached Thumbnails Fully Built 20B Package for sale-tec-1-coils-overview.jpg   Fully Built 20B Package for sale-tec-1-ems-closeup.jpg   Fully Built 20B Package for sale-bov-mounted-pipe-3.jpg   Fully Built 20B Package for sale-bov-mounted-pipe-2.jpg   Fully Built 20B Package for sale-bov-mounted-pipe-1.jpg
Old Jan 1, 2007 | 12:59 PM
five0rx791's Avatar
were you using the stock S5 tranny?
Old Jan 1, 2007 | 01:03 PM
Turbo 3's Avatar
Safety Guy
Yes
Old Jan 7, 2007 | 02:17 PM
Turbo 3's Avatar
Safety Guy
Open to offers on parts, but will not disassemble the engine. I do not have the ability to remove the flywheel so if you want the short block, it will have to come with it.
Stuff that can be sold separately;
- motor mounts
- turbo, WG, BOV
- Long/short block
- Clutch
- TEC 1 EMS with coil packs, trigger wheel, already wired and ready to go for a 20B. Comes with tuned fuel/ign map
- Polished intake manifold/TB set
- Fuel injectors (3-550cc, 3-1600cc), prefer selling sets of 3
- TII starter
All I can think of for the moment.
Only thing gone at the moment is the exhaust manifold, which would only work for FC's anyhow. This would still be a perfect setup for an FD.
Also willing to take out parts of the "package" that you don't want and drop the price accordingly.
New price for "package" is $14,500 shipped
Old Jan 13, 2007 | 06:29 PM
Turbo 3's Avatar
Safety Guy
Bump for the polar bear avatar and being in the middle of a MN winter
