Sponsored by: CARiD
When Replacing Thermostat Does it have to be Stock?
Old Oct 22, 2006 | 09:24 PM
MazdaSpeedRX7707's Avatar
MazdaSpeedRX7
when you replace your thermostat do you have to replace it with an oem one and by oem do you mean one from napa i heard that aftermarket thermostats are no good and you must use a oem mazda one but but stock mazda one do you think the napa one would work.
Old Oct 22, 2006 | 10:37 PM
06fc3s's Avatar
TIME ATTACK FD
Basicaly most people use the OEM one ( from Mazda) Because they are more dependable then any other ones that other manufacters make... PLus the Mazda Oem thermostat has a pin on outer rim to lets any excess bubbles pass though..
you can easily get them at the dealer or at rx7.com
Old Oct 23, 2006 | 08:17 AM
Chuck's Avatar
I just replaced my t-stat and I used the OEM one. Directions said to install with the jiggle pin upward. I was wondering, what the hell is a jiggle pin? Thanks for the info 06fc3s!
Old Oct 23, 2006 | 10:06 AM
Mahjik's Avatar
Mr. Links
Its to allow pressure/air across the t-stat.
Old Oct 23, 2006 | 11:08 AM
White94RX's Avatar
BMW Tech
I'd stick with OEM Mazda for stuff like oil filters, fuel filters, thermostats, etc.
sYnth.
Aug 19, 2015 06:27 PM
Joe428
16
Aug 19, 2015 06:24 PM
LMBTG
Aug 15, 2015 01:43 PM
