Low Vaccum=Blown Seal?
Old Mar 3, 2002 | 02:41 PM
MontegoRX7's Avatar
I am only seeing about 10-12 inHG of vaccum at idle. The car has been like this since I got it at 52K. The car runs ok, but is sometimes stumbles when I start it. Should I expect a rebuild in the near future? About how much are they?
Old Mar 3, 2002 | 09:52 PM
Could be a number of things.
But, a blown apex seal is a good possibility. I wouldn't drive it until you get a rotary specalist to look it over and do a compression test!
Patrick
Old Mar 3, 2002 | 10:20 PM
GsrSol's Avatar
Z06 powered FD
Rebuilds can be anywhere from $2500 - $7000+, average is probably $3500 considering you won't install it.
Old Mar 4, 2002 | 05:12 AM
bladz311's Avatar
I just blew mine . it sucks not having my baby. Sevenspeed.com said they would install a new motor with street porting and ceramic coated rotors for $3000.
Old Mar 4, 2002 | 06:03 AM
JONSKI's Avatar
5yr member, joined 2001
Don't fret, unless you got the car for real cheap and you have very little power, I doubt it's something like a blown seal. The only way to make sure is to get a COMPRESSION TEST!
Old Mar 4, 2002 | 07:57 AM
MontegoRX7's Avatar
I have had a compression test done, see my other post about it. All the pulses were the same height, so maybe rotor grooves? I dunno, I need to get someone to look at it. The car drives fine.
whinin
Mar 30, 2019 07:53 PM
ZacMan
Sep 19, 2015 09:20 PM
