Canadian Forum Canadian users, post event and club info here.
Auto to 5 Speed Conversion
Old Oct 17, 2006 | 04:02 PM
soulja77's Avatar
Has anyone ever done this?
Old Oct 17, 2006 | 04:12 PM
EDSRX3's Avatar
In what?
I've doneit with a 12a in an RX3. It was simple, direct bolt up!
Old Oct 17, 2006 | 04:28 PM
soulja77's Avatar
With an FC3S
Old Oct 17, 2006 | 04:43 PM
Nismo Convert86's Avatar
400WHP or bust
It can't be that hard just a pain in the ***, working under the dash sucks area suck, but i'm pretty sure it has to removed.
If you need the full conversion I have one fs.
Old Oct 17, 2006 | 05:34 PM
soulja77's Avatar
i have a 5speed parts car, but thanks
Old Oct 17, 2006 | 05:49 PM
doridori-rx7's Avatar
Navy MarCom
you can do a splice in for the rev. lights and autolock two wires and your done.. no need to fool around in/under the dash..
the only thing you need to decide on is if your going to graft in the 5spd tranny mount of make a custom one that extends to the auto mounts.. I did the latter, allowed me some freedom to dampen the tranny how I wanted. If you use the latter method you need to be sensitive as to where you run the speedo cable... as long you have a parts car then your laughing..
Old Oct 17, 2006 | 05:56 PM
400WHP or bust
Wouldn't that make it EXTREMELY hard to select gears? Maybe I'm a little slow but the pedal set does go under the dash right?
Old Oct 17, 2006 | 06:55 PM
misterstyx69's Avatar
Retired Moderator, RIP
He's talking about Wiring Nismo..
Old Oct 17, 2006 | 07:05 PM
400WHP or bust
Yeah I figured that out, but saying there is no fooling around under the dash isn't true.
Old Oct 17, 2006 | 08:31 PM
R.P.M.'s Avatar
Likes to swear....alot
No need to turn this into one of those threads again.
Like doridori said, you need to fabricate a trans mount. The floor pan in the auto cars is different. The pedal assembly can be changed while the dash is still in the car.
It'll be really easy since you have a parts car. Just be careful when your installing the 5spd flywheel onto the auto motor...and dont forget to put a pilot bearing in the end of the e-shaft!
Old Oct 17, 2006 | 10:58 PM
soulja77's Avatar
man sounds complicated and time consuming.... do shops do this? any recommendation?
i have 2 good engines. Would you guys recommend getting a performance clutch?
I am building a vert turbo rx7 to last...
Old Oct 18, 2006 | 08:28 AM
R.P.M.'s Avatar
Yeap, I'd be willing to do the swap, pm me if your interested.
Old Oct 18, 2006 | 08:51 AM
rx7racerca's Avatar
I'd recommend a performance clutch and pressure plate. The stock pieces on NA cars at least are weak.
Old Oct 19, 2006 | 01:37 AM
Navy MarCom
don't be obtuse.
Old Oct 19, 2006 | 01:39 AM
Navy MarCom
just finished one, plus I have the jig to do the brack
Old Oct 19, 2006 | 08:40 AM
Aaron Cake's Avatar
Engine, Not Motor
90% sure that there is a topic in the 2nd Gen Archives that covers it in detail.
