Differences between leading and trailing spark plugs??
Old Mar 3, 2002 | 10:14 AM
jeff8932612's Avatar
Question Differences between leading and trailing spark plugs??
Is there an actual difference in the plug. I know that the leading plug fires first and all. And the trailing fires second to help efficiently burn all the gas. But i was wondering if there is an actual difference in the plug. Thanks alot. -Jeff
Old Mar 3, 2002 | 01:33 PM
GsrSol's Avatar
Z06 powered FD
Yes, one burns hotter then the other. With NGK plugs the heat range is backwards then most domestic plugs. Stock you have a 7 and a 9 heat range, 7 is hotter, 9 is 2 steps colder. Most people run 9's all around and that would matter which hole they went into.
The1Sun
Mar 18, 2018 11:08 PM
Skeese
65
Mar 28, 2017 03:30 PM
VTECthis
Aug 24, 2015 09:01 PM
Joe428
16
Aug 19, 2015 06:24 PM
