New to RX-7's What to do??
Old Oct 10, 2006 | 10:32 PM
amnkeefe's Avatar
Newbie
Question New to RX-7's What to do??
This is my first import project and to be honest, I am lost. If you all could give me a list of good starter mods that would be nice. I want to keep it streetable but mean as hell. Oh it's a 94 with brand new stock turbos and about 75,000 miles.
Thanks in advance for your help.
Old Oct 10, 2006 | 11:13 PM
silentblu's Avatar
read the faqs section, in the 3rd gen section
Old Oct 17, 2006 | 07:37 PM
GothamRFD's Avatar
the rotarys are known for their over heating but you can reduce that by getting a down pipe. that takes alot of heat from the engine bay and the turbos will spool faster and you can hear them more. other things would be is to do a ziptie vacuum hose job,intakes,pulleys, racing catalytic converter ,catback Exhaust,
aluminum Air Separator Tank cause they tend to leak or blow up on you with out giving a warning witch would cause you mess up your motor. if you want to go up on more boost i would buy all the parts listed and a front mount intercooler,bigger injectors,fuel pump, fuel regulator, ecu upgrade not a piggy back and flywheel. if you have a good tuner around your area you should be able to see 400 whp at a safe 15 psi. enough to keep up with vipers and other high power cars cause of the 50/50 ratio the rx7s have.
alfred1976
RX-7 Audio/Visual Lounge
Dec 3, 2015 03:06 AM
Duc852
Sep 22, 2015 03:49 AM
