Inexpensive, Effective, Closed Loop Knock Control for Haltech ECUs
Old Oct 5, 2006 | 03:41 PM
pistonsuk's Avatar
Less cost than J&S, pulls both leading and trailing, no need for minimum split, adjustable max retard...
If your interested check it out:
https://www.rx7club.com/haltech-forum-62/closed-loop-knock-control-haltech-ecus-583563/
http://cgi.ebay.com/ebaymotors/Close...spagenameZWDVW
Justin
Old Oct 5, 2006 | 05:09 PM
SilvioRX7's Avatar
Would this work with a MicroTech?
Old Oct 6, 2006 | 03:39 PM
pistonsuk's Avatar
Does the MicroTech have a manual ignition trim function, like the Haltech?
Justin
Old Oct 7, 2006 | 12:21 AM
signofinfinity's Avatar
Coyote
Well,
What i did for closed loop on my wolf is similar. I purchased a J and S, connected the monitor output to the ignition trim feature, set up a linear scale for retard all. 20 deg max retard on the J&S is 1.03v. I set a linear table to retard ignition for every .Xv that the unit senses and retards. This way i retard the ign map
Justin, this way is a cost effective and easy way of doing it! nice work!
ps, i am using this on the wolf, but any ecu with a voltage trim input can be configured!
Old Oct 7, 2006 | 04:20 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
i'd hit it if it had everything included.
will it work with a gm knock sensor, or only a single wire?
Old Oct 9, 2006 | 04:05 PM
pistonsuk's Avatar
Originally Posted by signofinfinity
Well,
Wow, now that I see how the wolf can use an analog input to vary timing I can say that my circuit should work just fine in its current form with a wolf ecu. Just set the timing chart to pull 8 degrees (or any value to max retard) at ~0V input and then linearize up to pull 0degrees at 2.5V and above and this would do it.
Does anyone want to try this?
Justin
Old Oct 9, 2006 | 04:09 PM
pistonsuk's Avatar
It just needs to be a piezo electic style knock sensor that puts out a voltage proportional to the intensity of the knock. If this signal can be pulled from one of the two wires on a two wire knock sensor then it should work. It just needs to put out a voltage spike (like a variable reluctance sensor) when excited.
Justin
Old Apr 3, 2007 | 08:30 AM
pistonsuk's Avatar
Closed Loop knock Control Forsale
Check the 2nd Gen Forsale section if interested...
Justin
MoTeC
Sep 10, 2015 07:58 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
