somethings werid with my car help!!!!
Old Mar 1, 2002 | 11:51 PM
bt2's Avatar
bt2
Exclamation somethings werid with my car help!!!!
somtimes my car makes really loud noise coming from the turbo to the precat and sometines it doenst i think maye its a gasket ? plus somtimes my abs light comes on for no reason? one more thing i think its fuel cut but ....what happens is my car when in 4 or5 gear at around 5000rpm starts buck or seems lke it cant go anyfaster is this fuel cut? someone please help e out casuer i love my car and i waana fix whats wrong with it
thanks
Old Mar 2, 2002 | 12:27 AM
Erik's Avatar
Best of both worlds
Re: somethings werid with my car help!!!!
thanks
the hesitation "could" be TPS man...any check engine lights? i had a TPS go bad in my T2 and it sucked. it was on a long drive so in the beginning i dind't have power after 5K...the no power after 4K...then no power after 3K...
...buuuuuut, it could also be a clogged fuel filter or something. i'm guessing its happening at WOT if you're at 5K in 5th gear!!! LOL ...do you have enough mods to cause fuel cut?
i'm guessing you have a 89+ T2 since you say you have ABS (don't think it was avaiable on older T2s, maybe i'm wrong?) my light comes on occasionally as well. not sure what it means though. my clock sometimes comes on and off so maybe the soldering need to be touched up behind the dash...
also, if you have an 89+ check the codes (tutorial at www.1300cc.com ) and see if you find any errors, if your TPS is on the way out it might toss out a code and let you know...
good luck with the problem doooooood
autoxer
21
May 22, 2019 04:07 PM
gtcd
30
Aug 19, 2015 02:44 AM
NoMorePoison
11
Aug 18, 2015 11:18 AM
pzr2
Aug 15, 2015 08:29 PM
Marty RE
Aug 13, 2015 11:19 AM
