Sponsored by: CARiD
How safe is DIY Porting ?
Old Oct 2, 2006 | 11:19 AM
Ottoman's Avatar
always modding
hey guys,
While doing my rebuild, I decided to pick up the Judge Ito Intake template and do my Intake ports...
Well the time came to get down and dirty...
this template is pretty agressive!
i'm starting to worry that I might break into the water jacket....
how much meat is there to spare when ur grinding these things?....
I don't have an Exhaust template.. and i have brand new housings.. i'm too afraid to damage them... so i was planning on only smoothing them out inside..
will an Intake only port be useless without the exhaust porting?
Old Oct 2, 2006 | 11:40 AM
813KR$'s Avatar
TEAM MAZDA
Exhaust is not hard to port actually its like butter! Just open the exhaust to the metal sleeve and smooth the edges.
You should have plenty of metal to remove, you can always feel in the water jacket to insure you dont go too far!
Old Oct 2, 2006 | 12:24 PM
Latin270's Avatar
^^^ Well said. Just remember to be safe when porting. You can damage your eyes faster than you can imagine if you dont wear your safety glasses. I dont use templates for the exhaust. Like mentioned above I like to use the exhaust sleeve as a guide.
Old Oct 2, 2006 | 03:07 PM
Ottoman's Avatar
always modding
thanks for the info guys..
I'm more interested in the intake side tho.. not the exhaust...
and the safety margins....
Old Oct 2, 2006 | 03:42 PM
69datsun519's Avatar
Datsun510
porting
You should try to find some scrap end plates and do some practice porting on those... But that templete dosn't seem to extreme. I wouldn't be to worried about going into water jackets, just don't go to deep and go for a smooth transition... Thats what i think but im relatively knew at this.
Old Oct 2, 2006 | 04:53 PM
I F****D a mermaiiiid
smooth transition is the key. those templates look relatively safe. one tip that i would like to suggest is that unless you plan on building several motors or using those templates several more times i would use them as a gaurd on the housing. i would rather screw up the surface of $25 template than a $250 side housing.
the other tip is to use HIGH QUALITY grinding tools. a dremel is great for the "finish" work but it would drive me INSANE to work on port with JUST a dremel. get yourself a quality air powered pencil style grinder with some quality CARBIDE bits. Sharp tools are SAFER tools, both for yourself and the piece you're working on.
oh, and just go for it. you won't hit the water jacket so long as you don't don't go too deep. if you're looking at the housing from the broad face where the rotor spins try not to dig too much out of the "floor" of the port.
Good Luck!
Ray
Old Oct 2, 2006 | 06:25 PM
trochoid's Avatar
Old Fart Young at Heart
When grinding the intake ports, I take my thumb and forefinger and feel for the thickness left so I don't get into the water jacket. Very simple to guage thichness that way.
Old Oct 2, 2006 | 07:29 PM
mcfly's Avatar
I have the same template only my closing edge is much more to a point.
http://static.flickr.com/88/25872909...8dd65c_o_d.jpg
top left corner that is of the picture on top.
Old Oct 6, 2006 | 02:36 PM
Datsun510
porting templete
Hey guys im looking for some street porting templetes, i've heard the racing beat ones are kinda conservative. I want an aggressive street port, I have tried looking for the judge ito templetes but i cant find them. anyone know of where i can get a healthy street port besides mazda trix and racing beat, cuz i think there about the same. anyone anyone?
Old Oct 6, 2006 | 03:11 PM
PvillKnight7's Avatar
try to contact Judge Ito...or do a little bit of research and try porting without templates. Just don't port wider then the side seal path or port to deeply into the coolant passage. try the other forum (nopistons) for some good pics.
FlatVermin
22
Sep 27, 2015 05:42 AM
josef 91 vert
14
Sep 17, 2015 09:22 PM
