Mystery Objects, Do You Know What They Are?
Old Mar 1, 2002 | 12:52 AM
RotorMotorDriver's Avatar
Seven Is Coming
Hey, when I was taking out the storage bins for my sub box, there was a box, a gold box. It was mounted to the frame behind the drivers seat (under the storage bins) what does this do? Also, there is a wire that goes through the floor back there to. It has a two connector plug that hooks into the stock wiring harness, is this the fuel pump wires? If not, what is it? Not to worry, I dont plan on removing them or anything, I was just curious as to what they do. If the box is like an old amp or something from the stock stereo then Ill take it out, but it doesnt look like the Clarion one on the passenger side...Basically until I know what it is, im leaving it alone .
~T.J.
PS - It's an 85 GSL with the nifty radio and the joystick in the middle just in case you needed to know.
Old Mar 1, 2002 | 12:54 AM
Pittdp's Avatar
the box it the factory amp, and the wires go to your fuel pump.
Old Mar 1, 2002 | 01:21 AM
abeomid's Avatar
actually the two silver ones are factory amps. The gold box with a huge wiring harness coming out of it is the cruise control computer.
Old Mar 1, 2002 | 01:54 AM
Seven Is Coming
Yeah, its the big gold one with the huge harness. Ok cruise control eh? I know what the amps look like, so that all good and the fuel pump wires, thats good to know...Thanks Guys
~T.J.
Old Mar 1, 2002 | 02:16 PM
Pele's Avatar
Right near Malloy
Cut one fuel pump wire and install a switch... Good for anti theft and deflooding.
Old Mar 1, 2002 | 04:39 PM
V8kilr's Avatar
dont do that,it could damge your engine if you try to start it,go under the dash and the relay is right there in plain sight just right of the colum,it controls fule and spark,hook a switch up to that and you will cut them both so your not sparking with no fuel.
Skeese
65
Mar 28, 2017 03:30 PM
LongDuck
Oct 7, 2015 08:12 PM
Dripping Springs
Aug 28, 2015 09:55 AM
Cameron38
Aug 19, 2015 06:08 PM
