Swaybar parts
Old Sep 23, 2006 | 04:20 PM
Jabberwocky's Avatar
Swaybar parts
I just got my Widefoot mount in the mail. Worth every penny. Very well machined and well made. Even comes with metric grade 12.9 bolts (in other words, very good forged bolts)
Racing beat front sway. The swaybar is big and heavy. I snapped the endlink bolt Racing beat supplied after driving around for 10 minutes. I hate to think what would happen if it happened on the track. DO NOT use the cheap a$$ bolt they supply. It is very likely lower that a metric grade 8.8 bolt (Equavilent to SAE 5). Go out there and buy your own partial thread bolt the size is M10x1.25x55 in a metric grade of at least 10.9. I swear, the stuff that racing beat makes is junk, they keep using cheap material to cut corners.
Tanabe front swaybar, smaller than the racing beat, similar price. Diammeter is about 114mm is made from hollow chromoly according to tanabe. Good bar, the car is much more neutral with this that the freaking oversize racing beat bar.
Old Sep 23, 2006 | 06:28 PM
SoontobeLS1'd's Avatar
pro-liberty
Diameter of the bar is 114mm??
Old Sep 23, 2006 | 11:10 PM
Er. I mean 1.14 inches. Roughly. I don't have the proper tools to measure it precisely.
Old Sep 24, 2006 | 11:27 PM
WidefootRacing's Avatar
Talking
[QUOTE=Jabberwocky]I just got my Widefoot mount in the mail. Worth every penny. Very well machined and well made. Even comes with metric grade 12.9 bolts (in other words, very good forged bolts)
Hi Jabberwocky,
Glad you like the Widefoot Mounts! The bolts are overkill (10.9's would be
fine), but no worries about them breaking. ;-)
BTW, I agree that a 114mm front bar would be a little much - sort of a reverse
DeDion suspension! 1.14" sounds better. At least your mounts would take
it (but not the frame rails...).
David Breslau
Widefoot Racing Co.
Old Sep 25, 2006 | 06:23 PM
KevinK2's Avatar
Originally Posted by Jabberwocky
Racing beat front sway. The swaybar is big and heavy.... freaking oversize racing beat bar.
32mm solid bar. It's like taking the superb double wishbone front suspension and welding an I-beam across it.
Heedlessone
288
Sep 16, 2018 07:22 PM
driftfcbuckey
The Bad & Fugly Members
Dec 2, 2015 05:48 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
