Spacers needed? 17x7.5 +45 wheels, 215/45-17 tires, on S5 FC
Old Sep 22, 2006 | 09:54 PM
daten's Avatar
I want to put 17 x 7.5 wheels with a 45mm offset on my 1990 GXL.
Tirerack recommends 215/45-17 tires.
From nearly 3 hours of searching, the best I can gather is it might work in the back but not in the front, without spacers.
What size spacer should I use then? is 15mm enough? is 20 better?
Do I need them in the front and back for the wheels to line up?
And does that tire size sound correct?
Old Sep 22, 2006 | 10:05 PM
RETed's Avatar
15mm should be more than enough.
-Ted
