Clutch problem
Old Sep 21, 2006 | 05:22 PM
wisconsinrx7's Avatar
Clutch problem
Having a problem with my Dad's 85 GS. Started a short time after he changed the gear lube in the tranny (5 speed). Not sure if it could be related as its different fluid. We've done this before without causing problems.
After he drives a short distance the clutch will not work and stays close to the floor and slowly returns. If you pump it a number of times it works for awhile. We have notied bubbles when checking the fluid level for the clutch. When pumping the clutch I do notice more small bubbles.
Old Sep 21, 2006 | 05:27 PM
justint5387's Avatar
CPS Motorsport
Try bleeding the clutch, if the problem persist then you should put in new clutch master & slave cylinder and new line.
Old Sep 21, 2006 | 06:54 PM
GoT's Avatar
GoT
i've got the same problem.
i've bled the clutch. so now i should get new clutch master and slave cylinder?
Old Sep 21, 2006 | 06:59 PM
CPS Motorsport
Yes, most of the time when one goes bad... They both goes bad...
Old Sep 21, 2006 | 07:16 PM
GoT's Avatar
GoT
are these parts RX7 specific, are they easily obtained or expensive and rare? i've only got a few hundred bucks left to spend and need to get it all ready asap so i can sell my other car (neon chrysller 2001). poor students need cash.
Old Sep 21, 2006 | 08:00 PM
trochoid's Avatar
Old Fart Young at Heart
Bubbles indicate a leak in the system somewhere. If it's not coming from the bleeder, replace all of it, master, slave and hose, and be done with it for the next 15 years. Well worth the 100 bucks or so in parts for the peace of mind.
Old Sep 21, 2006 | 08:16 PM
85 FB's Avatar
7-less
Go with replacing all of it. I did that with my setup, much better feel. The parts should be easy to come by, but count on having an auto parts store having to special order them. Try to avoid buying from Auto Zone. Spent only $50 from them but the stuff was junk. Both items leaked. So, I went to Olympus Auto Parts (probably a local chain for me, I don't know) and spent about $80 and haven't had a problem since. Try to find a place that specializes in import parts. The stuff I got from Olympus were made by Tokico, versus some generic maker from Auto Zone. Big difference in what they looked like, too!
Old Sep 22, 2006 | 08:11 AM
Thanks guys. Ordering the parts today.
Old Sep 22, 2006 | 08:26 AM
John64's Avatar
What?
Replace both at the same time. Be ready to have very cramped hands and alot of cursing. Getting your hands up there to do a few million1/4 turns to get the nuts off.
Old Sep 22, 2006 | 08:40 AM
blwfly's Avatar
kiwi from downunder..
lol thats so true i had to have so many rests cause my hands cramped up rediculous why they made it so hard to get at
u agree with all i replaced both master and slave only costed 60ish at the parts store
Old Sep 22, 2006 | 02:33 PM
trochoid's Avatar
As an additional side note, take care when installing the slave bolts in the tranny. They tend to strip out the aluminum threads in the bell housing easily. I've had to drop a tranny and retap for a larger bolt because of this.
Old Sep 22, 2006 | 02:42 PM
Rogue_Wulff's Avatar
Too old to act my age
And those bolts are even harder to get at due to the beehive oil thingy.
After removing my beehive, I discovered someone had used trochoid's fix for the stripped bolt hole.
Enzo1944
Sep 6, 2015 08:57 AM
vmerino
Sep 5, 2015 11:26 AM
