Would i need a camber kit if I install 16" rims?
Old Sep 21, 2006 | 12:08 PM
dj55b's Avatar
alrgiht, so i've got this deal to get some 16x7 rims off one guy locally he's currently running tokico blues with Racing beat springs ... now 2 things ... i've read through some posts and couldn't really find much.
Would I need a camber kit to go with wheels that big? I've heard from some people locally here that when you decide to go over the overall stock diamiter of a tire camber may need to be adjusted would this be true?
Also reading from few post someone said that 15" on our cars is the best for overall performance, due to the fact that you actually need a little side wall to take the impact?
Thirdly, how much more of a stiff ride will the car be now with the lower profile tires?
Old Sep 21, 2006 | 12:28 PM
DriftFB's Avatar
Reno Rotary.
Unless your adjusting in positive camber I don't see what your even talking about. Giving more positive camber would bring the top of the wheel/tire closer to the strut/spring. You should never need a camber kit for larger wheels.
And as for a stiffer ride because of the lower profile, unless the roads are bombed out around where you live, or if you rear end is sensitive enough to tell the difference between 55-50 series sidewall and a 45-50 series sidewall, don't worry about it.
Old Sep 21, 2006 | 12:44 PM
gypsyvk's Avatar
As Drift said, wheel diameter has nothing to do with front end alignment. The problem you are more likely to have is fender rub and to some extent that will depend on the tires. I can tell you for a fact a 245/45 16 WILL RUB over bumps. I have a pair on the rear of an 84 gsl.
Old Sep 21, 2006 | 01:24 PM
DriftFB's Avatar
Reno Rotary.
Oh yeah, wheel offset is of course a big factor, what I said is anywhere from completely correct of absolutely wrong depending on the offset.
Old Sep 21, 2006 | 01:47 PM
Glazedham42's Avatar
Resurrecting Gus
Cutting the springs on your Civic? Yes.
Change the wheels on the 7? No.
Old Sep 21, 2006 | 01:49 PM
OnlyOnThurs's Avatar
TACOCAT
^^OMG glazedham! How are ya man? So are you out of the RX7 game permanently?? You had one sexy FB!
Old Sep 21, 2006 | 02:41 PM
Resurrecting Gus
Glad to see that someone has actually missed me. I'm planning a return to the FB scene. I'm going to be graduating college in December at which point I hope to get a job and purchase another FB. My car is still around on the boards if you check. Kim has put some Rx8 seats in it, Supercharger from Rotaryshack, and some other goodies. IT's nice to see someone continuing on with my project. I'm ready to get back behind the wheel of another FB though. Wish me luck....
Old Sep 21, 2006 | 04:22 PM
trochoid's Avatar
Old Fart Young at Heart
Lower profile tires can stiffen up the ride for 2 reasons. They should have a stiffer sidewall and some need to be run at a higher pressure. Inflate your's up to 40 psi and see how the ride comfort changes.
Old Sep 21, 2006 | 04:55 PM
dbragg's Avatar
Say hello to Mr.Wankel
i have 16x7 and 16x8 on my car. you dont need a camber kit.
Th0m4s
Feb 26, 2019 02:04 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
