A question for all you "experts"
Old Feb 28, 2002 | 08:47 AM
NM_Silverback's Avatar
Question A question for all you "experts"
The situation:
One of my turbo blades was damaged causing the bushings to wear out causing a lot of smoke. There was enought oil to cause an oil streak to form at a minor air leak by the IC. I'm currently replacing everything but I noticed when I pulled off the injector assembly the front injector was clean but the rear injector was coating with a black carbon deposit. So is this coating from the oil or is it caused by something else?
So put on your thinking caps and let me know if I need to check something while I'm re-assembling everthing.
Thanks.
Old Feb 28, 2002 | 10:44 AM
rx7ofmine's Avatar
Time to check the compression. You may have a bad rotor back there.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
