Suggestions need for locating exhaust leak
Old Sep 15, 2006 | 12:20 PM
aGoGo's Avatar
Hello,
I would like to get the exhaust leak figured out. I think the high pitch sound is from some where close to the turbo. Anything I can try to have good understanding about where it is?
Thanks
-X
Old Sep 15, 2006 | 12:27 PM
classicauto's Avatar
Crash Auto?Fix Auto.
start the car while its up in there air, get underneath it and feel around for exhaust leaks
Old Sep 15, 2006 | 12:54 PM
aGoGo's Avatar
Can I spray anything to help? Soap water? (Just a guess)
Old Sep 15, 2006 | 01:14 PM
Mankdrake 2661's Avatar
Mazda goes MMMMMMMM
Soapy water would probly burn off too quick.
Old Sep 15, 2006 | 02:32 PM
spiderx7's Avatar
my muffler installation guy uses a 2 foot hose sort of like the tranny cooler size .places one side on his ear the other in the vicinity of the leak with the car on and on the lift.
Old Sep 15, 2006 | 03:11 PM
aGoGo's Avatar
cool, good idea
Old Sep 15, 2006 | 03:21 PM
kungfuroy's Avatar
Chicken Adobo
mornings are getting colder, start it up on a cold morning and see if you see any vapours coming from any of the flanges
Old Sep 15, 2006 | 03:28 PM
Turbonut's Avatar
With the car at idle have someone place rags over the end of the tailpipe(s) momentarily. The noise will increase and you'll be able to pinpoint the leak.
Old Sep 15, 2006 | 03:44 PM
TRRAPLN's Avatar
(Terraplane)
This is what I just did.
Block off the exhaust flange after the down pipe with a thin piece of wood, plastic, masonite. I used a piece of plastic. Cardboard might work too.
Remove the O2 sensor.
Make a cork fitting to insert in the O2 bung hole. I used a plastic cork from a champange bottle. Drilled a hole in the top and inserted a small hose.
Attach the other end of the hose to an air compressor. Again I used a secondary regulator adjusted down to 3 PSI or so.
Turn air on a spray for bubbles using soapy water.
Small bubbles are usually tolerable. Your looking for big bubbles.
Spray around the exhaust manifold, turbo to manifold gasket and downpipe gasket.
I had bubbles around the exhaust manifold. Checked for warp and sanded it flat.
Re-used the expensive gasket and the leak is gone.
Kyo
Apr 13, 2019 09:24 AM
sypath
Aug 16, 2015 12:06 AM
