Help Please, FD dies at idle with high RPM
Old Feb 27, 2002 | 07:16 PM
Brian_93's Avatar
T-88 FD
I went to put air in my tires , and all the sudden my car started acting up. When Iam at a complete stop I have to keep the Rpms up so the car well not die, and it kinds of hestaties under normal throttle, but as I begain to gain speed its fine. Any suggestion. Fuel filter ?
I just changed my leading plugs with 11.5 race plugs?
thanks
Old Feb 27, 2002 | 08:38 PM
skunks's Avatar
I'm a CF and poop smith
same exact thing happen to my brothers fd but we were at a stop light, anyways it was the pressure senson, the vaccume line came off. in anycase it on the top of the engine near the fire wall right near the brake master cylinder. its a little plastic box which says pressure sensor on it i think. ill take a photo of it later if you can't find it.
goodluck
Old Feb 27, 2002 | 09:37 PM
Brian_93's Avatar
T-88 FD
I checked the pressure sensor, and it was fine. What else could it be?
Old Feb 27, 2002 | 10:37 PM
P'cola FD's Avatar
Hamado things my way!
Check the O2 sensor
Old Feb 28, 2002 | 02:23 PM
rx7speed811's Avatar
Accepting Donations.
try adjusting the idle, if you havent done so already. that will probably fix your problem.
13
Jan 9, 2018 11:19 AM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
rx7shirley
Sep 2, 2015 02:11 PM
