my CIA i made up...kinda
Old Sep 13, 2006 | 07:32 PM
jonesfromindia's Avatar
Goofyrotor
well the idea isnt new, a lot of people use this are for their CAI. but i decided to use another stock intake tube. heres my picture ideas. should be complete tomorrow. only thing im worried about is if the filter will fit between the brake duct and inner wheel well cover. sorry they are big too lazy to resize them.
Old Sep 13, 2006 | 08:00 PM
mikaz's Avatar
The Extremist
your Air Flow Meter must be level for it to work by the way.. but nice job on using another stock intake tube!
Old Sep 13, 2006 | 08:04 PM
Goofyrotor
its been like that for 2 months. i used the bonex or bonez i forgot the name, kit and it tells you to do that in the drawing a 12 year old did for directions. worst 130$ spent ever. the only thing im adding is the extra tube to the fender.
anyone know where i can get a 45^o rubber elbow piece? doesnt fit flush with the hole im making. im most likely gonna use PVC pipe for that little bend.
any reason why i shouldnt?
Old Sep 13, 2006 | 08:06 PM
Goofyrotor
i just realized i put CIA instead of CAI on the thread title. embarrassing.
Old Sep 13, 2006 | 08:08 PM
lupin's Avatar
Rupanrx
isnt the stock intake hose restrictive? I am gonna get my hands on some abs and try to make a good cai after I get my megasquirt done
Old Sep 13, 2006 | 08:31 PM
Sideways7's Avatar
The stock tube is basically the same size as the opening to the TB, plus its a lot smaller than the opening in the afm, so I don't think its restrictive. I have the bonez kit too and I think its perfectly fine. You get the same thing as all the other kits but cheaper since you aren't paying for a name. As for the afm orientation, there are directions on how to do it right on aaroncakes site here: http://aaroncake.net/RX-7/intake.htm I haven't done it myself since mine was already installed when I bought the car and I didn't realize anything was wrong until after my engine died.
Old Sep 13, 2006 | 08:33 PM
cmanns's Avatar
Smoke moar
whats that silver thing on the pipe?
Old Sep 13, 2006 | 08:45 PM
Goofyrotor
what silver thing? between the 2 hoses? i know you are kidding.
Old Sep 13, 2006 | 08:56 PM
Sideways7's Avatar
Hopefully you are talking about the thing under the rad hose. If so, thats a filter for the air pump intake.
Old Sep 13, 2006 | 09:30 PM
sykminded's Avatar
Aspiring Neophyte
I've been thinking about doing the same thing. I even have the spair intake hose! haha.... but, I like my windsheild fluid. We're close buddies, and I'd hate to get rid of him. haha.
That's pretty slick though. Noticeable difference? What kind of filter are you/will you be using?
Old Sep 14, 2006 | 12:08 AM
Goofyrotor
bonez kit from the rx7store. seth from pure sports gave me an rx7 that was completly stripped and he had one just sitting with an engine in it. pulled out that engine, shop burnt down with the engine in it. had the whole intake included mass air flow and tubing got that sweet idea. im suprised its there cus some people went through a lot of the left over cars there.
Old Sep 14, 2006 | 02:46 AM
Carzy Driver's Avatar
Law Breaker
get rid of the air pump silencer and you'll even better air flow
Old Sep 14, 2006 | 03:06 AM
NZConvertible's Avatar
I'm a boost creep...
It's stock so it has to be restrictive right?
It's over 3" in diameter, which is huge for an engine that'll struggle to break 200hp.
Old Sep 14, 2006 | 07:52 AM
NeCr0mStR's Avatar
I just wanna hump my car.
If PVC gets hot it will breakdown and give off noxious fumes and chemicals. Be careful
Old Sep 14, 2006 | 07:59 AM
jeremy's Avatar
male stripper
i was going to see if you were hiring. i'd love to drop my stripper position and be a playboy style spy. 0013B.
Old Sep 14, 2006 | 08:19 AM
umi415's Avatar
I have a similar set up. The diference is I used 3" 45 degree elbow intercooler piping from the feed end of the MAF to the cone filter and the cone sits where the washer fluid bottle used to be.. Basically what you have but instead of the stock intake tube I have 3" chrome pipes. mines A TII also. Anyway nice job.
JP
Old Sep 14, 2006 | 08:30 AM
SpooledupRacing's Avatar
I would'nt say they are restrictive just not smooth so u dont get that nice strait flowing air in there..
Dave
TougeRoads96's Avatar
Rotary Love
what about when it is wet out?
Old Sep 14, 2006 | 11:13 AM
RE_GTUs's Avatar
is it weird that on my s5 the washer fluid is on the p.s. firwall?
there is a huge write up on how to do this with a honda prelude cai,
I think I will just go to a muffler shop and buy some 3" piping and go to auto zone and buy some diff. deg. of couplers.
how did you cut out that hole?
Old Sep 14, 2006 | 12:35 PM
Law Breaker
easy, that's called water injection
Old Sep 14, 2006 | 08:13 PM
sykminded's Avatar
Aspiring Neophyte
Actually, I can imagine the stock pipe is better than metal. It won't absorb heat nearly as much, and the air will be cooler. Metal get's HOT. Think about it.
As for when it's wet out, the only thing you should be worried about it damaging is your precious filter. A little water isn't going to hurt the intake.
Old Sep 14, 2006 | 08:31 PM
Sideways7's Avatar
If you're using a k&n style filter, it shouldnt be a problem since they are designed to get wet. If it gets totally soaked it might be a good idea to re-oil it, but thats it.
Old Sep 17, 2006 | 12:40 PM
Zokus's Avatar
"Mellow Yellow"
Wrong, PCV will not do that. ABS will.
Old Sep 18, 2006 | 04:08 AM
Actually he's right and you're wrong. Most of the plastic in the car (including the engine bay) is ABS.
Old Sep 18, 2006 | 09:08 AM
Aaron Cake's Avatar
Engine, Not Motor
You're going to want to rotate that AFM so that it is either in the stock orientation or directly upside down. If you don't, gravity effects the flapper door and changes the readings. In your case, it will be pulling it closed so the car will run leaner which is likely a good thing. I have actually measured this difference (by failing emissions tests when my meter was hung so the door gets pulled open).
joel(PA)
Oct 4, 2015 06:07 PM
SSpyderX
1st Gen General Discussion
Sep 29, 2015 04:37 PM
