Engine dies when I slow down
Old Sep 13, 2006 | 07:20 PM
mini720's Avatar
Newbie
I have an 86 NA that the engine dies when I slow down or stop, it starts up again with no problem ....I changed the plugs and wires, but nothing changed...The headlights and dash lights flicker when at idel but I don't know if this has anything to do with it...... This is my first RX7 and I know very little about them , but I love the car and the performance. PLEASE HELP ME!
Old Sep 13, 2006 | 07:23 PM
general_macbeth's Avatar
I would check for intake leaks first. This is the primary failing of all idle problems.
Old Sep 13, 2006 | 09:37 PM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
check the brake booster vacuum line.
Old Sep 13, 2006 | 11:35 PM
R_PROWESS's Avatar
F[x]3S ENG.
was you a/c on?
Old Sep 19, 2006 | 07:13 PM
justbajan's Avatar
Newbie
Engine still dies
I changed my user name....... I also changed a vacuum on the brake booster but it did not help, the other lines look good but I have no way of doing a smoke test to look for more leaks.......And yes the problem is worst when the AC is running......PLease give me what ever you can come up with to help.... Thank you very much for your input.
Old Sep 20, 2006 | 06:34 PM
Go48's Avatar
Troubleshooting idle problems is a real PITA, but the systematic approach is the best way. Check the TPS, check the BAC valve, check the output of the alternator, look for vacuum and air leaks by spraying a mist of water near the lines with the car idling, check the grounds. Get a Haynes or factory workshop manual (free for the download--see the FAQ) if you don't know how to do those things. You also might try adjusting the dashpot on the throttle body linkage. Good luck!
Old Sep 20, 2006 | 06:57 PM
justbajan's Avatar
Newbie
Thanks guys I will give it another shot this weekend and let you know what happens.
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
incubuseva
14
Sep 3, 2015 12:37 PM
86glxNA
Aug 22, 2015 08:54 PM
