What can I use from Vette LS1?
Old Sep 13, 2006 | 02:52 PM
PolePosition's Avatar
I've got a local LS1 from a Vette that I can possibly get for the low. I was wondering what can I use from it, and what do I need to replace with the Camaro part?... this will be going into an FC... I know that I can't use the 6spd from the Vette and I cant use the oil pickup and oil pan, but what else can I not use?
Or more specifically, since I have the option of buying only what I need.. what should I make sure is included with the motor?
Thanks!
Old Sep 13, 2006 | 06:09 PM
Crash Test Joey's Avatar
Zero Rotor Motorsports
Everyone I've seen use a Vette motor has swapped to F-body accessories (alternator, A/C, P/S etc) due to placement. Also an F-body throttle body can use the Mazda throttle cable, as opposed to the Vette's electronic drive-by-wire setup. I'm sure you could use the Vette setup but I'm not sure how tough it would be to wire up properly.
gabescanlon
V-8 Powered RX-7's
47
Mar 21, 2016 12:45 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
gabescanlon
V-8 Powered RX-7's
Sep 24, 2015 03:41 PM
BUSTN
V-8 Powered RX-7's
Sep 2, 2015 04:39 PM
