Sponsored by: CARiD
i need some help on buying a rebuilt kit
Old Sep 13, 2006 | 02:36 AM
amadormazdarx7's Avatar
Thumbs up i need some help on buying a rebuilt kit
has any one bought a rebuilt kit from rotorsportsracing.com
i was looking at the racing beat and maztrix one i dont see some seal that come includled. or if you know some where else better and cheaper some info will help thanks this rebuilt kit is for 1988-1987 TII. the number on the side is the quantaties it comes with
Part Qty 86-91 Master Kit
Price > $1289
Inner Water Coolant Seals - TEFLON ENCAPSULATED SILICON 4
Outer Water Coolant Seals - TEFLON ENCAPSULATED SILICON 4
Inner Rotor Oil Seal 0-rings - VITON 4
Outer Rotor Oil Seal O-rings - VITON 4
Dowel Pin O-rings - VITON 4
Rear Stationary Gear O-ring - VITON 1
Front Cover O-ring 1
Nylon Washer for Front Cover Pulley 1
Oil Metering Pump O-ring 1
Oil Filter Base O-Rings - VITON 2
Tension Bolt Washers 18
E-shaft pulley bolt o-ring - VITON 1
Injector Diffuser O-rings 6
Crank angle sensor O-ring 1
Oilpan gasket (shipped separately) 1
Front cover gasket-metal (shipped separately) 1
Front Main Seal 1
Rear Main Seal 1
Corner Seal Springs 12
Side Seal Springs 12
Corner Seals 12
Side Seals 12
Apex Seals w/ dual springs / 3mm seals come with single springs 6
Waterpump to Block gasket 1
Oil Tube Gasket 1
Hylomar 1
Brushable 1
Grey 999 1
Thermal Plug 1
Oil Pump Chain 1
Rotor Oil Seal Sets 4
Rotor Oil Seal Springs (Inner) 4
Rotor Oil Seal Springs (outer) 4
Instruction Set 1
for the apex seals you can pic either 2mm or 3mm
Th0m4s
Feb 26, 2019 02:04 AM
astrum
24
Nov 15, 2017 08:44 AM
Ciclovnz
Oct 18, 2015 03:04 PM
sYnth.
Aug 19, 2015 06:27 PM
