Msd: 6al Vs. Dis-2
Old Sep 12, 2006 | 09:51 PM
blazer1313's Avatar
Audio Cronic Syndrome
Question Msd: 6al Vs. Dis-2
Everyone uses MSD 6AL. One per coil if running through a distributor or 3 if running direct fire. I MAY possibly run both. I have a GSLSE and am going to switch over to the FC leading coil and keep the trailing stock running through the dizzy. Only because there's no real cheap way to convert to the FC trailing coils.
Anyways, I am looking at the MSD DIS-2. (2 channel vs the 6AL which has 1 channel) I was told that the DIS-2 will not work for rotories. Is this true?
Old Sep 12, 2006 | 10:01 PM
RETed's Avatar
You cannot run the DIS-2 if your thinking of using the leadings in any part of the install.
-Ted
rgordon1979
40
Mar 15, 2022 12:04 PM
alfred1976
1st Gen General Discussion
Oct 1, 2017 09:51 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
GKW
Sep 28, 2015 04:34 PM
stevekh
May 7, 2002 10:36 AM
