Anyone with Rtek 1.7.......
Old Sep 12, 2006 | 08:44 AM
socalfct2's Avatar
Is anyone else with the Rtek 1.7 running unbelievably rich? I understand to fully tune my air/fuel I need to upgrade to a better management system and that in high boost applications it's better to run richer than leaner, but this is rediculous. I've also used the stock air/fuel adjuster to lean it out as much as possible, but it doesn't seem to make much difference. My T2 stinks like fuel bad. I also don't have any exhaust leaks, blown pulsation dampner, or fuel leaks. Anybody have this same problem?
Old Sep 12, 2006 | 08:46 AM
red87tll's Avatar
needs a cheaper hobby
My T2 stinks like fuel bad x2
Old Sep 12, 2006 | 08:58 AM
socalfct2's Avatar
I'm also guessing by leaning out a little more I can produce more power.
Old Sep 12, 2006 | 10:08 AM
Mankdrake 2661's Avatar
Mazda goes MMMMMMMM
Yeah mine did. An air/fuel computer really helps fine tune it.
Old Sep 12, 2006 | 10:12 AM
The Wankler's Avatar
FKITALL
You mean a wideband?
Old Sep 12, 2006 | 10:34 AM
socalfct2's Avatar
If you go microtek or haltech do you guys still run stinky as heck with a tuned set-up?
Old Sep 12, 2006 | 01:03 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
i had rtek 1.7 and never had any rich problems.. check your PD
Old Sep 12, 2006 | 02:24 PM
Digi7ech's Avatar
I break Diff mounts
My car bucks and hesitates at the injector switch. I've yet to put a wideband on it though.
Old Sep 12, 2006 | 02:31 PM
blue87t2's Avatar
^ I had the exact same problem and i could never figure out how to fix it, so i just pulled it off and ran stock.
safc II
S4 to S5 turbo
FD fuel pump
Full exhaust
TID
EVC III
Just coundn't figure it out ,it says on the web site it doesn't need a afc for it so i don't know maybe its injectors....
cameron
Old Sep 12, 2006 | 02:57 PM
socalfct2's Avatar
Could a clogged charcoal canister make a car stink like burnt fuel?
WyomingTII
Rtek Forum
Oct 26, 2015 05:26 PM
lnlreaper
Sep 27, 2015 09:59 AM
