Need help installing a harness bar
Old Sep 11, 2006 | 10:49 PM
jolly's Avatar
The top of the rear shock tower is bolted by three 14mm bolts.
I want to lengthen these fasteners to bolt on the harness bar, which is 1/4" thick. How do I do this?
I have not taken apart the shock, so I am asking if these bolts fall separately, or are they part of the assembly at the top of the shock tower?
I am hoping thet they aren't part of an assembly.
Old Sep 12, 2006 | 02:19 AM
rynberg's Avatar
They are part of the assembly. What you need are different nuts that are threaded all the way through. The OEM nuts aren't, and so won't thread on enough.
1/4" thick sounds like a VERY thick plate though, is this some kind of custom bar or something? I don't recall the M2/Raceshop bar being that thick.
Old Sep 12, 2006 | 07:44 AM
jolly's Avatar
Thanks. So, I just need different nuts, good.
I could be over-eyeing the plate thickness. It is a M2 bar.
Jolly
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
