stock twin turbo set up?
Old Feb 27, 2002 | 02:44 PM
Rotor Nut.
how much can i push from the stock twins?
Old Feb 27, 2002 | 03:08 PM
SPOautos's Avatar
Hey, where did my $$$ go?
the most I've ever seen is 400RWHP from the stock twins. I'd say without running them to the edge you could run 360-375.
Later,
STEPHEN
Old Feb 27, 2002 | 05:30 PM
artguy's Avatar
WTB** Very Low Miles 94-95
depends on your mods....but honestly..pushing anything over maybe 10-11 lbs will simply damage your turbos. they just are not quality equipment and cannot handle all that heat.
I pushed 13lbs and went thru two freshly rebuilt sets within the year.
if your turbos are on the last leg and you have the fuel mods to support it as well as the ecu and intercooler mods(heat damage) then go for it....run 15lbs if you want...just dont expect them to last more than a month lol.
also expect some possible engine damage from the increased temps.
good luck
if you want more power go single or go with the m2 set
immanuel__7
89
Sep 5, 2015 10:23 AM
