DIN Panel Gauges
Old Sep 11, 2006 | 09:25 PM
BillM's Avatar
RX-7's since 1980
DIN Panel Gauges
Recently completed a DIN panel and 3 gauge install, hope to post a pdf file once I fugure it out..
Old Sep 11, 2006 | 09:39 PM
JDMRevolution's Avatar
Make that money!
Looks good man!
Old Sep 12, 2006 | 09:25 AM
BillM's Avatar
RX-7's since 1980
dont have a place to host the file since msn groups requires anyone who wants to view it to sign up anyone interested i can email it (pdf file around 500K)
Old Sep 12, 2006 | 11:23 AM
Brian7's Avatar
SnapDrive.net
Old Sep 12, 2006 | 04:02 PM
BillM's Avatar
RX-7's since 1980
thanks snapdrive works
http://www.snapdrive.net/files/103405/DIN%20Gauges.pdf
Old Sep 12, 2006 | 04:10 PM
prescription 7's Avatar
RX7club addict
Nice! thats in my next set of mods
Old Sep 12, 2006 | 04:12 PM
afterburn27's Avatar
Lets Go Hokies!
That is one hell of a great write up!
I have my water temp gauge in the same spot, and I'll probably put fuel pressure and oil temp in the other two spaces. I have my boost gauge on the steering column for a better line-of-sight.
Old Sep 12, 2006 | 06:45 PM
BillM's Avatar
RX-7's since 1980
Yea, its scarry trying to watch the boost go to 10psi WOT, going 70mph and staying in one lane...
Old Sep 12, 2006 | 06:58 PM
RE-Amemiya's Avatar
Not the company
Not bad
Old Sep 12, 2006 | 07:11 PM
Maximum's Avatar
Ditto! At first I thought this was kind of trivial but that writeup was definitely worthwhile. Fantastic
Old Sep 12, 2006 | 08:13 PM
Nuvolari's Avatar
Veni, Vidi, Vici
Nice. I have a two din one but have'nt decided to put it above or below the head unit.
Looks clean. How do they look when driving ?
Old Sep 12, 2006 | 08:42 PM
Juan's Avatar
Im a tall midget.
I put mine under the headunit because its easier to see. Heres an old picture of my setup:
Old Sep 12, 2006 | 09:24 PM
BillM's Avatar
RX-7's since 1980
Like the stock gauges they are hard to read at night but I felt that I would be reaching for the radio so I put the gauges on the bottom. It' would be an easy swap to move them up because of the connectors.
Thanks to alot of info from this forum I took on this project and just wanted to put all the info in one place.
Old Sep 13, 2006 | 08:32 AM
sonix7's Avatar
here is a pic of Defi's in a CF din panel for fun.
Old Sep 13, 2006 | 09:35 AM
BillM's Avatar
RX-7's since 1980
I was looking at DEFI D gauges but the mechanical boost was discontinued and they were a bit out of my price range. Gotta love the Kenwood radios, picked mine up new for $130. Sounds fine.
Old Oct 26, 2006 | 12:47 AM
krzemienr's Avatar
I like this set up a lot, however, aren't they hard to read when you're actually driving? also where did u get the DIN Panels for the gauges.... now that I think about it, ne1 know if they make pods that are like those pictured here, exept they tilt a little up? or is that a total custom project...
Old Oct 26, 2006 | 07:54 AM
TheRxForSpeed's Avatar
Vrooooom....PSHT
The DIN panel I got was from thompson automotive http://www.thompson-automotive.com/T...tive_Home.html, i believe they actually had some sort of add on you could use with the din panel to give it more of an upward angle, however i don't think that is necessary i can see my gauges fine when mounted underneath the radio. Just my opinion tho.
Old Oct 26, 2006 | 12:39 PM
Frankie B's Avatar
1993 Type R
Here's mine, no problems viewing them.
Old Oct 26, 2006 | 02:15 PM
the_saint's Avatar
I prefer having the gauges above the head unit.
Old Oct 26, 2006 | 02:36 PM
Vrooooom....PSHT
Here's mine
Old Oct 26, 2006 | 04:26 PM
dis1's Avatar
www.silverbulletrx7.com
Here is a cloe pic of mine: http://www.silverbulletrx7.com/mods/DIN.jpg I have oil temp, boost control and a turbo timer.
Old Oct 27, 2006 | 12:46 AM
jkstill's Avatar
Searching for 10th's
Nice writeup.
Did the Miata DIN plate fit as is?
Also, do you think 2 of them would fit properly to fill the entire space?
I'm going to pull the stock stereo in my car. It never gets used.
Old Oct 27, 2006 | 01:00 AM
krzemienr's Avatar
TheRxForSpeed.. what type of gauges are those? I like them cuz they look like the stock ones from far away...
Old Oct 27, 2006 | 01:07 AM
silentblu's Avatar
they seem like autometers, but i'm not sure, the carbon fiber ones
Old Oct 27, 2006 | 02:24 AM
krzemienr's Avatar
I though of something and I'm curious to see if anyone has tried it.... ne1 ever mount some gauges where the visor by your head is? not sure how that would look/work...just curious
