Sponsored by: CARiD
1 month and blown engine?
Old Sep 9, 2006 | 12:39 AM
RX-7_Fiend's Avatar
Ok so for some reason, I went just got an oil change and was surprise to find sludge.. but I changed the oil put in about 7.5 quarts 4 quarts to clean out the sludge and the rest for the car... The car seems to be fine after that!
So i left my car outside, next thing i try to turn it on 3 days later, and I hear Bang Bang, when i try to rev it to higher RPMS.. So i car dies when it reaches 3000 rpm
with a big bang and off..
Flame came out of the exaust once, and then black smoke now it seems to be only black smoke? Any ideas guys? Plz help!
Oh yea there is a minor oit leak but I am goin to get a mechanic to check all that out i just want some input on what the problem could be. before i bring to the mechanic
and the biggest question is! Is the motor kaputz??
Oh yea! its a 1993 FD r1 with a rebuilt and 13k on motors!
Old Sep 10, 2006 | 10:09 AM
RX-7_Fiend's Avatar
also my battery is not rechargin, so I think my alternator is gone i alrdy checked the battery its good!
I post this because my friend said all this could be b/c of the alternator!
He says fuel is being released and the alternator is not being effective in lighting up the sparkplugs so I get a higher amount of fuel then i should when the sparks light up with the extra fuel thats why i hear the Pow Pow noise and the little fire that comes from the exaust..
Anyone know if this is possible. I've been seriously conteplating on giving up the car due to the fact that i only got it 1 month ago and all this is happening but i love the 7 and I want to fix it up! can anyone plz give me some input. Its been 2 days and i am still dumb founded!
Old Sep 12, 2006 | 10:27 PM
RX-7_Fiend's Avatar
The symptoms seems like the car is flooded how do i properly deflood it to see?
Old Sep 12, 2006 | 10:37 PM
R_PROWESS's Avatar
F[x]3S ENG.
egi fuse i think its called. pull it and it will cut the fuel while you crank.
tiger18's Avatar
right mate deflood
1) remove all four spark plugs (either replace with new or clean them with carb cleaner and dry in an oven)
2) remove the large fuse on the front cross member labeld EGI
3) put key in ignition and crank engine over for 25 seconds (this will pump out all the fuel locked inside the engine through the spark plug holes)
4) using a syringe or something else inject a few squirts of oil into both the front and rear rotor housing (through the bottom 2 spark plug holes)
5) turn the engine over manually by attaching a socket on the alternator nut and winding until you think the engine is rotated like 3 times
6) replace the dry or new spark plugs and igntion leads (make sure you get the wires on the correct plugs)
7) replace the EGI fuse
8) try start car up
ok?
Old Sep 12, 2006 | 10:38 PM
tiger18's Avatar
let me know if you want more info or get stuck
Old Sep 12, 2006 | 10:53 PM
iceman4357's Avatar
make sure the map sensor isnt unplugged it makes it run like ***
Old Sep 12, 2006 | 11:01 PM
RX-7_Fiend's Avatar
I tried the Egi fuse today.. no good..
turned on the car for a couple of seconds to unflood with egi fuse out but no good,
it helped though but still didn't start one time it started for like 1 second and then gone!
Old Sep 12, 2006 | 11:02 PM
KeloidJonesJr.'s Avatar
strictly business
Make sure the oil drain plug is tightly screwed on.
Old Sep 12, 2006 | 11:05 PM
RX-7_Fiend's Avatar
how would i check the map sensors, i got a haltech e6k, and i am trying to learn about it!
tiger18's Avatar
the egi alone wont unflood good enough,, u need to do the full proceudre,,,and also check that map sensor,, thats is a good point
Old Sep 12, 2006 | 11:06 PM
RX-7_Fiend's Avatar
hmmm, oil drain plug! omg that could be it, because it started happening right after i changed my oil!
Old Sep 12, 2006 | 11:07 PM
RX-7_Fiend's Avatar
anyone post a pic of where the spark plugs are! i couldn't find em! on my car and
me and my friend looked! i feel stupid! hehe
Old Sep 12, 2006 | 11:18 PM
Mahjik's Avatar
Mr. Links
Arrow
Locate the spark plug wires, and follow them down:
http://robrobinette.com/sparkplug_wires.htm
Old Sep 12, 2006 | 11:24 PM
RX-7_Fiend's Avatar
I, Love, You, All!
Old Sep 13, 2006 | 12:13 AM
strictly business
Trust me, once you run your car and the oil drain plug pops off, it's gone(warped housings maybe and rotors). Don't even overlook that.
Old Sep 21, 2006 | 03:28 AM
XxMerlinxX's Avatar
Team Benjos Captain
^ I love the picture of the oil draining out and forming a puddle right next to the cigarette butt.
Old Sep 21, 2006 | 03:29 AM
strictly business
That pic was taken on a canyon, not even near anyone's house.
Th0m4s
Feb 26, 2019 02:04 AM
cdn
14
Sep 10, 2015 06:23 AM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
