Powerplant frame cracked
Old Feb 27, 2002 | 12:29 AM
Crazy_Jake's Avatar
My powerplant frame has a crack in it about two inches long. Can I buy a reinforced or stronger than stock PPF?
How expensive are these things?
Thanx, Jake
Old Feb 27, 2002 | 12:38 AM
LT1-7's Avatar
John
I have one for sale. PM me
Old Feb 27, 2002 | 12:51 AM
JoeD's Avatar
yeah...Mazdaspeed PPF. supposedly they are 10% stronger than stock, but if you cracked the stock one, chances are that you will crack the Mazdaspeed one soon. instead of replacing the PPF every so often, how bout you solve the wheel hop issue which cracks the PPFs in the first place. even with the stock PPF, if you dont have any wheel hop, you wont crack/break it no matter how much power you are running.
BTW, the Mazdaspeed unit is $350, and is painted a very pimp red...good for a 5-8 RWHP boost and better mid-range torque.
Old Feb 27, 2002 | 12:53 AM
Flybye's Avatar
It's never fast enough...
Originally posted by JoeD
.....BTW, the Mazdaspeed unit is $350, and is painted a very pimp red...good for a 5-8 RWHP boost and better mid-range torque.
Let me know what **** you smoke
black99's Avatar
Lurking..................
You can buy the Mazdaspeed one too which is stronger than stock you can get it from www.rx7store.net should be a under $400.00 like they said around 350.00
It's not that hard to crack a PPF... All it takes it some wheel hop, with whichever one you put back in it I would suggest you upgrade the suspension to try to keep this from happening again like JoeD said.. I am going to get the M2 products to try to help this soon.
Old Feb 27, 2002 | 12:56 AM
lesd's Avatar
I'll sell mine for $70
-Les
JoeD's Avatar
nah...i pass on grass.
BTW Mike, where you been lately??? oh man...you sure missed out on some really good action in the Lounge recently!
Old Feb 27, 2002 | 12:59 AM
Crazy_Jake's Avatar
So how do I stop the wheel hop problem, which BTW is quite severe?
Old Feb 27, 2002 | 01:01 AM
black99's Avatar
One way to try to minimize it is to get the trailing arms and toe links from these guys..
http://www.m2performance.com/
Old Feb 27, 2002 | 01:02 AM
Flybye's Avatar
Eh. You know how it is. Boy meets girl. Girl takes away time from boy. Boy forgets about certain things for a little while
Does ANYONE know what effects nylon bushings will do to the powerplant frame? Oh, I DO have the entire M2 rear kit.
Old Feb 27, 2002 | 01:05 AM
JoeD's Avatar
you could get a KAAZ limited slip differential, and say buh-bye to wheel hop for sure. or you get M2's trailing arms and toe links, and replace all the rear bushings and hope that you will no longer have wheel hop...
Crazy_Jake's Avatar
Can't I just weld the crack?
Old Feb 27, 2002 | 01:07 AM
black99's Avatar
Well you can weld you PPF crack, but I am not sure how long it will hold, as I have never done it myself...
Old Feb 27, 2002 | 01:09 AM
JoeD's Avatar
sure...but what problem will that solve?? you will still have wheel hop, and chances are they you will crack the PPF again either from the same spot that you welded or somewhere else. will you then weld it again?
Old Feb 27, 2002 | 01:10 AM
Crazy_Jake's Avatar
How will a LSD from KAAZ stop wheel hop?
Old Feb 27, 2002 | 01:30 AM
Crazy_Jake's Avatar
How do I do the quote thing?
Old Feb 27, 2002 | 01:32 AM
black99's Avatar
Hit that little "qoute" button in who's ever post you want to qoute, see it to the right of "report" and "edit".. For how the LSD eliminates wheel hop, do a search(button underneath the red car at the top and search for "KAAZ LSD", you should find info
Old Feb 27, 2002 | 01:33 AM
FDokinawa's Avatar
OK, im a little bit of an expert here...cracked my PPF 3 times...re-welded it all 3 times. It's not worth getting the Mazdaspeed one. Now I have a Kaaz diff(blew the stock one out) and I'm still getting MAD wheel hopp. But it's a lot more fun making slow turns now.
Im looking for a good, cheap, set of trailing arms and toe links here in Japan. I'm also looking for a set of Bushings(no luck there yet). Hopefully this will solve all my problems.
Old Feb 27, 2002 | 02:11 AM
Dr Wankel's Avatar
Altitude SUCKS!!!
How would the diff have any effect on wheel hop? Correct me if I'm wrong but wheel hop is caused by the rubber bushings in the stock trailing arms storing up energy.
Oringinally posted by FDokinawa
Did it crack in the same place all 3 times?
Old Feb 27, 2002 | 07:33 AM
Lightbulb
When I cracked my stock PPF at the drag strip (in three places) Chris at RP told me this:
Don't reweld it; it'll just keep breaking. Get the Mazdaspeed one; it's almost indestructible. Steve Kan has been running it for over a year w/no problems, and he drag races the hell out of his FD every weekend. Steve installed the Mazdaspeed after his stocker kept cracking. (This isn't an exact quote; going off memory here )
I was going to go w/the Mazdaspeed, but a local guy had an extra he was nice enough to give me for $50. I haven't been back to the drag strip since, and it's held up fine.
Btw, if you have access to a lift and some tranny jacks, it's not too difficult to replace the PPF. My buddy Alan and I did it in just over an hour, and we're far from being mechanically inclined
Hope this helps--
Old Feb 27, 2002 | 12:01 PM
Crazy_Jake's Avatar
Does anyone make polyurethane bushings for the FD?
Old Feb 27, 2002 | 12:09 PM
SPOautos's Avatar
Hey, where did my $$$ go?
If you can weld just weld the PPF and spend you $$$ on trailing arms and toe links from either PettitRacing.com or M2Performance.com
I have Pettits kit and it works great. I never get wheel hop.
Later,
STEPHEN
Old Feb 28, 2002 | 09:13 AM
FDokinawa's Avatar
No it was in different places.....I’ve reinforced it with some added steel.
Think about this...if the Mazdaspeed PPF is 10% stronger than stock what if I’m pushing more than 10% horsepower than stock?? Well I’m pushing way more than 10%...so a mazdaspeed PPF is a waste of money.
Just do what SPOautos suggests save the money and get tow links and trailing arms.
Old Feb 28, 2002 | 11:58 AM
Bucrx7's Avatar
Mazdaspeed PPF can handle 10% more of the stock's PPF limit. Not 10% more of the stock's hp. If that was the case then everyone should be breaking PPF left and right.
Old Feb 28, 2002 | 07:05 PM
JoeD's Avatar
hp has nothing to do with the PPF breaking or not. you could be running 700 hp for all it matters...the PPF breaks from wheelhop, not horsepower.
