Sponsored by: CARiD
replacing fuel pump and fuel filter question
Old Sep 1, 2006 | 03:33 AM
EjCabrera's Avatar
i'm pretty much stuck right now because i do not know how to stop the fuel pressure. i checked out my fsm and it said to refer to f-95 and said these steps. the problem is my motor is already out. is there anything i should do to stop the pressure in the lines or can i just take out the filter and pump or will fuel splash everywhere?
Old Sep 1, 2006 | 10:57 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
there shouldn't be any pressure in the lines if the motor is out. the stuff that leaks out is just from gravity.
Old Sep 1, 2006 | 12:06 PM
EjCabrera's Avatar
thanks man ima get right on it then
Old Sep 2, 2006 | 04:10 PM
oo7arkman's Avatar
In the Garage
I may be too late to help you with this one but check out http://www.robrobinette.com/ it has lots of helpful hints with things such as changing the stock fuel filter.....which is kinda a pain in the butt....
Old Sep 6, 2006 | 02:43 PM
White94RX's Avatar
BMW Tech
Just pull the fuel lines off, but have a rag over the end to catch any fuel, or prevent any spray if pressurized.
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
