non-sequential advice needed
Old Sep 1, 2006 | 03:04 AM
EjCabrera's Avatar
i'm going to drop my non-sequential in pretty soon and i was wondering if porting the wastegate is actually necessary. when i got the turbos done at rotary reliability and racing they said that it is not necessary to do the porting but i would like to know your guys input. also the to wire it up i found a diagram on the forum and i would like to know if its a good one to use or if you guys have a better one. thanks
Attached Thumbnails non-sequential advice needed-truetwin_hoses_colored_exposure_exposure_resize.jpg
Old Sep 1, 2006 | 03:08 AM
BuckyFD3's Avatar
GT4088R
Depends on your exhaust system.
Old Sep 1, 2006 | 03:24 AM
EjCabrera's Avatar
what do you mean by exhaust like midpipe issues. okay the car has a streetport and that includes the exhaust ports. it has a downpipe, hiflow cat, and catback.
Old Sep 1, 2006 | 04:05 AM
CantGoStraight's Avatar
What's your point ?
What computer are you running and do you ever plan on going to a mid-pipe ? You don't mention a boost controller. As long as you can maintain 10 psi of boost without spiking or creep then your wastegate is fine. If you can't then it will need to be ported.
Old Sep 1, 2006 | 07:56 AM
burnoutking999's Avatar
Mentos and Magnums
If youre going nonsequential anyway then do it right and take off the turbos and dont cut corners... at the same time the wastegate is right there, its cheap insurance agianst the alternative!
Old Sep 1, 2006 | 10:16 AM
Improved FD's Avatar
^ what he said
if there is even a slight chance you will run a midpipe, you need to do it
Old Sep 1, 2006 | 10:33 AM
rc51king's Avatar
it aint no secret
what they said
Old Sep 1, 2006 | 12:05 PM
EjCabrera's Avatar
okay that said where the hell can i get it ported
Old Sep 1, 2006 | 01:24 PM
Mentos and Magnums
any capable machine shop should be able to handle it given the right specs. i beleive Improved FD knows of an excellent bit f info on where to get the template and spring.
Old Sep 1, 2006 | 02:13 PM
amp's Avatar
amp
old yella
or you can do it yourself if you have access to a diegrind..
Old Sep 1, 2006 | 05:04 PM
cewrx7r1's Avatar
Eye In The Sky
Do it your self, a Dremel tool is good enough to do this.
Old Sep 1, 2006 | 07:13 PM
sydewayz7's Avatar
yea
Yea i used a dremel and those sand papper barrel things..It worked good as hell and then hit it with something to make it a lil smoother.
Old Sep 3, 2006 | 12:55 AM
EjCabrera's Avatar
crap i looked at the turbo's and didnt know where to start since everything was done by rotary reliability and racing. how do i get to the wastegate. i dont want to start taking stuff off and realize that there was a gasket there. any help would be great thanks.
Engine Management Forum
11
Nov 9, 2015 01:15 PM
fastrx7man
33
Sep 2, 2015 09:42 PM
tridav3
Aug 17, 2015 06:32 PM
